New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
89 registered members (4WD, alarmguy, AandPDan, andyd, 03s, Arob, 4 invisible), 1,777 guests, and 18 spiders.
Topics306,004
Posts5,284,527
Members71,558
How to kill single tree only without harming others? #5213411 09/15/19 02:10 PM
E
Ed_Flecko Offline OP
E
I have this, what I call, "weed" tree that I'm trying to kill that was about 20-25' tall...before I cut off the branches!
smile
Now, I'm left with about six (6) sawed off branches about 6' tall. I want to kill this tree only so maybe in a year or so, the roots have loosed enough that I can either dig it out or use a cable come-along to pull the branches out by the roots.
On one side of the tree, about 6' away, is a palm tree and on the other side, about 6' away, is a pine tree. I want to kill this tree only without harming the health of the other two trees.
I'm thinking of making fresh cuts on the remaining 6 branches and then immediately painting some sort of herbicide, etc., on the cuts so the tree sucks the chemical back to its roots and kills it?
Suggestions on how best to kill this pesky tree?
Thank you,
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213421 09/15/19 02:14 PM
B
bullwinkle Offline
B
I've killed weed trees by cutting 2 inches deep, all the way around the trunk-that cuts off nutrient flow to the upper part of the tree, it dies, then start cutting off the dead branches, then the trunk, down to the ground. Takes a year or two, though.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213430 09/15/19 02:20 PM
B
billt460 Offline
B
Pound a solid copper "nail" into the trunk about a foot above ground level. You can make one out of a piece of 3/8" or so diameter copper bar stock.
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213443 09/15/19 02:26 PM
doitmyself Offline
Garlon (triclopyr) ester in diesel fuel. Cut the stumps near the ground and paint the stump with the mixture. It will be absorbed by the cambium layer and kill the roots. I believe Ortho has a product with Triclopyr.
Tordon RTU will also get the job done.
There is always the very slight risk that trees of similar species close together can have root grafts and the pesticide will translocate into the other tree. This shouldn't be a problem with different species trees, but be careful. Follow directions. More is not better.
Google Cut stump treatment: I.E.,
https://mdc.mo.gov/blogs/more-quail/are-you-using-right-cut-stump-herbicide
https://cals.arizona.edu/extension/ornamentalhort/landscapemgmt/prunning/cutstump.pdf .....talks about root flashback
Glyphosate hasn't worked as well for me in this application. Plus, it causes cancer in California shrug
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213522 09/15/19 03:48 PM
J
JLTD Offline
J
Why don't you just cut it down? With poison/herbicide, you risk the other trees as well.
Lates.
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213535 09/15/19 04:05 PM
F
Fawteen Offline
F
You can't just cut it flush and then grind the stumps? Should be pretty simple, and a stump grinder will make short work of whatever you can't get with your chainsaw.
Re: How to kill single tree only without harming others? [Re: billt460] #5213593 09/15/19 05:31 PM
M
maxdustington Offline
M
I thought you hammered a copper pipe in the tree and filled it with dish soap.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213594 09/15/19 05:34 PM
E
E
I certainly *might* just cut it down, especially if I'm not comfortable that an herbicide won't harm my nearby trees.The Tordon Herbicide that "doitmyself" suggested above sounds promising, so I think I'll research that more and see if that might, safely, do what I want.
Ed
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213597 09/15/19 05:38 PM
Dadillac Offline
I was told by a landscaper that if you debark a complete ring around the trunk the tree will dies quickly. Not sure if true as I have never done it.
Don
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213614 09/15/19 05:59 PM
4WD Online Confused
Online Confused
Six deep 1/2 holes at 45 degrees around the trunk ... use a 6 ounce super syringe to fill holes with Round Up daily
Re: How to kill single tree only without harming others? [Re: Dadillac] #5213690 09/15/19 07:18 PM
Cujet Online Content
Online Content
Don
That method does not work on melaluca trees (also called paper-bark or tea-tree oil trees)
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213740 09/15/19 08:19 PM
B
Blaze Offline
B
I cut down some willows at ground level and then drilled holes in the stump. Poured 25% Triclopyr down the holes. Nearby trees are fine and willows dead. Willows can be pesky sometimes because of the roots but so far all is good.
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5213835 09/15/19 09:50 PM
P10crew Offline
Ed I swear the dude in the shop next to me single handedly kills a single tree every week. Every time I see him in the shop he is constantl running back and fourth to the printer.
If you want to chemically Kill a tree it’s very easy. Pramatol
Re: How to kill single tree only without harming others? [Re: maxdustington] #5214007 09/16/19 05:37 AM
B
billt460 Offline
B
Never heard about the dish soap part of it. But a copper pipe will certainly work..... If you can get it into the trunk. Depending what kind of wood the tree is. Copper pipe can easily bend and collapse when pounded with a hammer, because it is so soft.
Re: How to kill single tree only without harming others? [Re: Ed_Flecko] #5214332 09/16/19 12:19 PM
J
JLTD Offline
J
I think we need pictures of the offender and the innocents next door.
Lates.
