Ummm... Redline is supposed to based on POE. Unlike PAO that most synthetics use.
POE's cling to metal better, are natural seal softeners, have built in cleaning traits and handle water intrusion better.
PAO's don't stick to metal, don't absorb water, and need either conventional or POEs added to hold additives in suspension.
It's not though. It is almost entirely PAO based.
That's depressing. Though I noticed the stuff they sell in the big parts stores doesn't really talk about esters on the packaging.
Their gear oils still proudly boast they are Ester based.
Did they go all PAO and POE, or is it PAO, HC and POE?
I believe the product has been probably almost all PAO based for a very long time, likely with a decent slug of POE on top of it to provide the benefits that it affords. I doubt the product has ever been majority POE based, simply that it had enough of it in the blend to be significant and thus warrant mention. Mobil's old "Tri-Syn" formula was at the time remarkable for including three different synthetic bases in various quantities: PAO, POE and AN's as another example.
Yeah, years ago when I talked to Redline, they said it was POE and PAO, simply because of cost, but they said it was a significant portion of the mix.
But then when I asked them, I had to special order anything Redline, and it only came in white bottles.
So I wonder if they've clawed back the amount of POE to make it cost acceptable.
