overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
117 registered members (830Lee, ABN_CBT_ENGR, AandPDan, 2015_PSD, 2K2AcuraTL, 4WD, 5 invisible), 2,049 guests, and 53 spiders.
Topics306,007
Posts5,284,601
Members71,558
Engine burning oil #5212968 09/15/19 06:49 AM
E
Espada Offline OP
E
My engine is burning oil and there is oil ash on the spark plugs and i dont know if its valve stem or piston rings, if i tried motor doctor 9990 made by Mannol and smoke and burning stops or oil burning is reduced does that indicate that the Piston rings are worn
Re: Engine burning oil [Re: Espada] #5212990 09/15/19 07:16 AM
J
joekingcorvette Offline
J
I think the BITOG diagnosis team will need more information such as: the make model year and miles on the vehicle. Length of ownership and some past history and more details. cheers
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Engine burning oil [Re: joekingcorvette] #5213053 09/15/19 08:13 AM
E
Espada Offline OP
E
1998 Mitsubishi lancer with 272000km had engine rebuilt or hauled at 250000 and it started burning oil again
Re: Engine burning oil [Re: Espada] #5213124 09/15/19 09:01 AM
I
irad Online Content
Online Content
I
Go back to the rebuilder and ask him the following:
Where the rings replaced? If so where oversized rings used?
Where the cylinders rehoned?
Where the valves or valve guides replaced?
Are the valve caps/seals new?
Was a new cylinder head gasket installled?
Was the cylinder head also rebuilt?
The oil is coming from the rings, head gasket or valve stems. Dry and wet compression testing can narrow it down.
Good luck.
Re: Engine burning oil [Re: Espada] #5213178 09/15/19 10:16 AM
2
2004tdigls Offline
2
judging by your location (Egypt) cold starts would not be an issue, try a 20w50 or sae 50, the higher viscosity might help a bit
Re: Engine burning oil [Re: 2004tdigls] #5213228 09/15/19 11:07 AM
E
Espada Offline OP
E
I am already using 20w50, some adviced me to use oil treatment like Mannol doctor 9990 while others said to keep the oil levels in check as the oil treatment will do more harm than good
Re: Engine burning oil [Re: Espada] #5213303 09/15/19 12:45 PM
A
andyd Offline
A
Keep oil in between dots on the dip stick Do a compression test If all 4 plugs were oily maybe the valve seals were forgotten? Do you have a list of parts and machine work performed?
Thick oil is better grin2
Re: Engine burning oil [Re: andyd] #5213305 09/15/19 12:46 PM
E
Espada Offline OP
E
The entire engine like valves and piston rings and all of the engine parts
Re: Engine burning oil [Re: Espada] #5215527 09/17/19 07:22 PM
B
Bonnelvr92 Offline
B
My car is burning oil too (because of valve seals) I want to see if Lucas heavy duty oil stabilizer will help as a temporary fix, because I don't know if the cracked valve seals letting the engine oil burn with the gas hurt any internal parts inside my engine.
