Originally Posted by kschachn
Originally Posted by AVB
I watched my cousin do that on his semi one time. He cleaned the cables then coated them with dielectric grease and wondered why the truck wouldn't start. I took the cables back off and cleaned off the grease and explained that dielectric meant non conductive.
Speaking of electric grease I picked up a tube from home depot, it was a conductive, anti-corroision, and anti seize grease.
Originally Posted by atikovi
Regular grease is an insulator. I'd never get it on a battery post when commercial products specially made for that purpose are available.
Here we go with this nonsense again. You do want a dialectic grease, you'd never want an electrically conducting grease in this application (in fact there are very few legitimate uses for electrically conducting grease). This question seems to pop up now and then, the grease on the terminal does NOT inhibit conduction but instead prevents moisture intrusion and other benefits. Please inform yourselves on this subject before posting to a public forum.
Here is a previous thread on the same subject:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5157207/how-to-use-dielectric-grease
and the relevant link from that thread:
https://www.nyelubricants.com/stuff...ricating_electrical_connectors_final.pdf
Besides that there is a military study on the exact same subject somewhere.
It isn't nonsense when someone slathers it on the terminals thinking that it is going to improve the connection. The example I used with the semi involved a stack of copper lugs and a threaded battery post. The grease created a barrier because it didn't get scraped off like it would in other applications. I am not saying that it is common, just warning others that it can happen. It is also possible to create the same condition with a typical top post battery, but it is unlikely because of the physical scraping that normally occurs when installing the battery cables.
