1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
61 registered members (4WD, amblerman, ArrestMeRedZ, alarmguy, 86cutlass307, aquariuscsm, 6 invisible), 1,301 guests, and 48 spiders.
Topics306,081
Posts5,287,025
Members71,596
Cargo Trailers #5212450 09/14/19 12:35 PM
A
A_Spruce Offline OP
A
Hey guys,
I'm in the market for an enclosed work trailer, 6x12 with at least 6' interior height. Budget dictates buying a used trailer.
1 - What are good brands/manufacturers to look for, and why?
2 - What are the ones to stay away from, and why?
3 - Torsion axle or leaf spring? My opinion is spring over torsion for durability/longevity
4 - Tire age - how old is too old, even if the tires look to be in good shape? My opinion is 5 to 8 years
As always, thanks for your thoughts. cool
'03 Suburban
Re: Cargo Trailers [Re: A_Spruce] #5212454 09/14/19 12:41 PM
M
maxdustington Offline
M
I know that most trailer tires are junk so I would leave room in the budget for a new set right off the hop if you travel far from home. If you're a contractor using it in the city you live in you can probably let it slide or at least feel them out.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Cargo Trailers [Re: A_Spruce] #5212499 09/14/19 01:44 PM
ls1mike Offline
I change my trailer tires every 4 years regardless of use. However I do put 3000 to 5000 miles on them a year.
Last set were Carlisle Radial Trail HD, rated to 81mph. I put 19,000 miles on them in 4 years. They were great. 50 bucks each for 14 inch 205 75 Load range C
This summer I put the same tires on with load range D. They are great!
But for safety I wouldn't run trailer tires more than 4 or 5 years.
I doubt you will find a lot of torsion bar trailers, but not sure. Even my 32 foot TT that weighs 7800lbs has leafs, they have been great for the past 7 years.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Cargo Trailers [Re: A_Spruce] #5212641 09/14/19 05:18 PM
E
E365 Offline
E
Can’t answer all your questions, but I have an Aluma AE58. It’s an all-aluminum 5x8’, Made in Iowa. Build quality is pretty good. LED lights, torsion axle, aluminum wheels.
Expensive new, but if I needed another trailer I’d 100% look for something all-aluminum. Pretty much everything steel looks like trash before long in the salt states due to all the rust. Maybe look for something all-aluminum that’s used?
I love the torsion axle. Rides much better when empty vs leaf springs.
Quite possibly this was the best purchase I’ve made in my life. I’ve towed it an estimated 7,000 miles and have had zero issues. I still chuckle seeing pickups loaded up with stuff getting rained on. My cargo stays watertight and locked. Or 4x8 sheets hanging out the back of a pickup bed. Mine fit fully inside.
My tires are ~7 years old, so I’ll need new ones soon. Not worth the risk to go much longer.
Brand choice gets tough because cargo trailer makers seem to often be regional to avoid transportation costs all-over the country.
[Linked Image]
Whatever's on sale...
Re: Cargo Trailers [Re: E365] #5212670 09/14/19 06:23 PM
U
user52165 Offline
U
Ask this on RV.net in the trailer section
A great forum for everything RV and related
Re: Cargo Trailers [Re: A_Spruce] #5212682 09/14/19 06:42 PM
A
A_Spruce Offline OP
A
I don't live in snow/salt climate, thankfully, I don't usually have to worry about rust or corrosion. I do watch for such things, since you never know where something originated from.
I have figured that new tires will be a necessity, simply due to age, sitting, and sun rot. I might get lucky, we'll see.
Because I'm buying used, I don't have a lot of choice in what kind of axle it has under it. Torsion axles have become the norm, not opposed to them short term, but would rather have leaf springs for durability and longevity. The trailer will be used for tools, materials, and debris, so ride quality isn't a big concern.
Thanks for the thoughts, everyone, keep 'em coming if ya got 'em. cool
'03 Suburban
Re: Cargo Trailers [Re: A_Spruce] #5212707 09/14/19 07:26 PM
R
Rand Offline
R
what is your budget?
you can get new for under $4000
Re: Cargo Trailers [Re: A_Spruce] #5212828 09/14/19 10:24 PM
A
A_Spruce Offline OP
A
Budget is under $3000. I've seen several promising ones, nobody is returning emails though. I would love to go buy a new trailer, just can't swing it at the moment.
'03 Suburban
Re: Cargo Trailers [Re: A_Spruce] #5212880 09/14/19 11:54 PM
Nick1994 Offline
Used trailers are such a rip off, people ask way too much. If you do some searching, you might be able to find a new one really close to your budget. Then no tires to replace or wiring to mess with.
Here's a new one for $3,340
https://www.thetrailerspot.net/2019-pace-american-outback-6-x-12-enclosed-cargo-trailer-CkNg|P0e.html
And a 2018 for $2,699
https://www.trailertrader.com/2018-continental-cargo-tw610sa-enclosed-cargo-trailer-yQ6h|olg.html
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Cargo Trailers [Re: Nick1994] #5212895 09/15/19 12:59 AM
A
A_Spruce Offline OP
A
Thanks for the links. cool
Looking at this Continental, it's 2 years old and only $150 less than a brand new 2020 trailer. Judging from the number on the tongue, it's either a dealer or an auction flipper selling it, not necessarily a problem in this case.
'03 Suburban
Re: Cargo Trailers [Re: A_Spruce] #5214145 09/16/19 08:48 AM
supton Online Content
Online Content
Search, search and search some more. I lucked out and jumped on the one I got. It's a bit of an odd one, 6x14 single axle, but $2,300 I wasn't going to argue. Previous owner used for moving his motorcycle. After using it a few times, if mine were to go away for whatever reason, I may very well buy new. I like it that much. It's way way better for moving stuff than using my truck. I can walk in and not bang my head (but I'm only 5' 8" on a good day); no high floor to deal with.
I decided I liked the barn doors instead of a ramp. I can always make a ramp but I can't add barn doors; a ramp may need more unloading space. One downside was that as a single axle it's a low weight capacity of like 2k (trailer is around 1,600 by itself, 3k GVWR supposedly but as a cargo trailer it's not overloaded until there's no space left!), and to keep the trailer light they used luan for walls. Which makes loading or hanging things from the walls problematic. Which is ok for me, whenever I use mine it's simply packed in, good and tight.
I did get radials for a reasonable price. I plan to keep them covered when not in use, keep some of the UV off them, and then I'll probably replace around the 5 year mark.
I don't feel the leaf springs are that bouncy. It's a heavy trailer by itself. Maybe if it was a dual axle it'd be different. IMO mine works fine as a single axle, no scrubbing while turning. But I'm not moving heavy weight for long distances either.
Supposedly there are a lot of cheap ones being made in GA. Cheap steel, construction, whatever. Not sure what you need, but IMO many of the lower end cargo trailers are like cars. They can age out as well as wear out. At this price point buying new may be better, but realize you may be tossing after 5 or 10 years anyhow.
Not sure why they "all" seem to have gone to flat roofs but mine has a rounded roof and I'd think that'd be better for rain and snow.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Cargo Trailers [Re: A_Spruce] #5214198 09/16/19 09:40 AM
A
A_Spruce Offline OP
A
If I had the cash, I'd buy new and we wouldn't be having this conversation. LOL
I've seen a few decent trailers come across the block, but they have not been quite right or they've been scammer posts. Multiple checks a day to get on them as soon as they're posted, the good ones don't last long.
'03 Suburban
Re: Cargo Trailers [Re: A_Spruce] #5214202 09/16/19 09:47 AM
Online Content
c'mon, this is a America, that's what credit cards are for. LOL
No, nothing good lasts long. Story of, well, everyone's life.
Are there any local lots/dealers? I'm wondering if any of them get trade-ins. People moving up in the world, getting bigger/better. I think some RV dealers might dabble in cargo trailers too. Could go there.
Off-beat thought: what about gutting a travel trailer? It'd have to be cheap to justify it, and you'd have to build up from there, but I'm not sure what you are after--how heavy your stuff is, etc. Plus most travel trailers get cheap after the water damage is done, and usually that is from a failed roof.
Re: Cargo Trailers [Re: supton] #5214465 09/16/19 03:06 PM
A
A_Spruce Offline OP
A
Yes, I've got several dealers in close proximity. A few of them might have something used, and I have thought about checking with a few of them. Will check with RV trailer dealers as well, good thought.
I've thought about both a cheap RV trailer or a horse trailer and modifying them for my use, but if I'm gonna spend the money, it might as well be on something that's a little closer to what I need. Both travel and horse trailers are going for about the same money as the cargo trailer that I'm looking for. The other problem with these trailers is that they are not professional looking, nor would they instill confidence in clients who see me working out of them.
'03 Suburban
Re: Cargo Trailers [Re: A_Spruce] #5214479 09/16/19 03:41 PM
Srt20 Offline
Torsion axles last just as long as springs. IMO, they probably last longer, at least in rust belt areas.
I greatly prefer torsion vs springs. And would not buy a new small trailer with leaf springs.
Small trailers are built as cheap as possible. Not alot of profit margin in them. Grease the wheel bearings alot, and make sure it has radial tires. Fix anything else as it pops up.
