94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
QS Conv vs. QS HM vs. PYB
by Fordiesel69 - 02/17/20 01:09 PM
Kia Proceed?
by WhyMe - 02/17/20 12:44 PM
RIP Donald Stratton
by 02SE - 02/17/20 12:41 PM
WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
jds59, JimMorrison, bjfangjd, 45ander5, FlightRT
70725 Registered Users
115 registered members (01rangerxl, 2013ecof150, 2K2AcuraTL, 762fermeandyou, 55hambone, 14Accent, 8 invisible), 2,221 guests, and 26 spiders.
Topics301,580
Posts5,198,415
Members70,725
Waterproof stock finish that won't hide wood beauty? #5210939 09/12/19 11:50 AM
E
Ed_Flecko Offline OP
E
I have a shotgun stock that I'd like to refinish. I'm planning on using an Aniline dye for color.
After dying, I'm hoping to find a "finish" that will protect the wood (and maybe be waterproof, to some degree), hopefully have some level of durability, yet be easy to repair when it gets scratched, etc. I'm hoping the finish product can be used to produce a shine that would range from satin to gloss, depending on how many coats I want to apply. I will apply Renaissance Wax when I'm all done.
Out off all of my desired characteristics, what is most important to me is to not hide the beauty of the wood.
I'm sure there are trade-offs since I doubt any one product has all of these characteristics, but can you offer any suggestions as a starting point?
Thank you!
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5210952 09/12/19 12:04 PM
Stradbasher Offline
I would simply use shellac. This probably isn't a traditional stock finish, but it works well and can be readily polished and dyed if you like. I use aniline dyes all the time in shellac. If you want to retain the beauty of the wood, don't color the wood itself, but rather the transparent finish you put on it!
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5210960 09/12/19 12:15 PM
R
redbone3 Offline
R
I rub in clear epoxy glue, then go over it with fine steel wool when it's hardened. Put the glue in the refridgerator for a while first, so it doesn't go off too soon.
2014 Passat Wolfsburg, 1995 Miata.
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211000 09/12/19 01:27 PM
Dan55 Offline
I use this on my cherry furniture it actually make the surface harder. https://www.homedepot.com/p/Watco-1-pt-Rejuvenating-Oil-66051H/100187718 It can be refinished at any time even with wax coating. Watco makes a multitude of products, even a wipe on poly. https://www.rustoleum.com/product-catalog/consumer-brands/watco/
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211023 09/12/19 02:07 PM
T
Tyson Offline
T
Tru-Oil from Birchwood Casey has a long history of great results.
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211048 09/12/19 02:31 PM
dwcopple Offline
this:
[Linked Image from images-na.ssl-images-amazon.com]
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211110 09/12/19 03:43 PM
spasm3 Offline
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Waterproof stock finish that won't hide wood beauty? [Re: Tyson] #5211171 09/12/19 05:49 PM
B
Blkstanger Offline
B
Ding ding ding We have a winner!
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211181 09/12/19 06:10 PM
A
AVB Offline
A
Spray lacquer, it doesn't create layers. Each coat "melts" or amalgamates in to the last coat to make one layer. It makes it easier to touch up blemishes because it eliminates witness marks. There are some good write ups by noremf on stock refinishing on rimfirecentral.
Re: Waterproof stock finish that won't hide wood beauty? [Re: Blkstanger] #5211190 09/12/19 06:29 PM
H
HangFire Offline
H
Never a bad choice.
Various musings: http://hangfire.net
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211200 09/12/19 06:50 PM
I
IndyFan Offline
I
This is for a stock already in good shape......I had a beautiful Henry rifle with an American Walnut stock that had lots of character to it. I first rubbed it down with McGuire's Scratch-X, which is the automotive product for removing light clearcoat swirls in car finish. It is a very mild abrasive paste. It really shined up and glossed the finish which looked more of a matt finish when new. I then hit it with several coats of Howard's Feed N Wax, which really brought the wood grain out in a big way. It made it much more visible and brought out color that was much harder to see before. The difference was astounding. Of course, being a wax, it waterproofed it, or at least made it water resistant. The bonus was the nice citris smell after application.
I have a Henry Golden Boy and I've thought about doing this, but the grain isn't as prevalent as it was on the first one, which was a standard Henry .22.
18 Jeep JLUR Wrangler 3.6 25k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 135k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211261 09/12/19 09:01 PM
B
bruckus Offline
B
I would do 5-6 coats of tung oil depending on the shine you are looking for. Once dry apply your wax.
Re: Waterproof stock finish that won't hide wood beauty? [Re: Ed_Flecko] #5211974 09/13/19 04:51 PM
B
bsmithwins Offline
B
Another happy user of tung oil here. Easy to use and get good results. BSW
Re: Waterproof stock finish that won't hide wood beauty? [Re: HangFire] #5215830 09/18/19 06:31 AM
Sierra048 Offline
Never a bad choice.
Another vote for Tru-Oil. I stripped two Mosin Nagants down to the bare wood (Birch). Stained and finished with several coats of Tru-Oil. They both turned out nicer than I ever imagined.
2014 Nissan Frontier
2014 GMC Sierra 1500
Re: Waterproof stock finish that won't hide wood beauty? [Re: Tyson] #5215883 09/18/19 07:25 AM
Cujet Offline
I used Tru-Oil on my M44 restoration. It really looks amazing in person. Very deep gloss that is a real pleasure in person. I applied it in steps, following the instructions. Unfortunately, the pictures simply don't show the depth and gloss. It's much like an automotive clear coat, with a deep shine.
This was a $69 gun, that looked like absolute junk, coated in preservative.
[Linked Image from i.imgur.com]
