Anyone of you uses DIY deicer during winter? I use 2/3 Rubbing alcohol and 1/3 water. It works like charm (although smells like IPA for a while in the car) but recently found that it can bubble the car paint.
I detailed one of the cars the first time and noticed the paint bubbling near the top of the windshield on the hood. Searched a few detailing forums and they do not suggest using IPA over the car paint as it can bubble the paint. Most likely that is the reason in my case. I have been using liberally for the decade.
Prestone deicer contains methanol and ethylene glycol, not too sure if that is DIYable.
Does anyone use anything else?
Thanks in advance.
Thanks in advance.
