Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
QS Conv vs. QS HM vs. PYB
by Fordiesel69 - 02/17/20 01:09 PM
Kia Proceed?
by WhyMe - 02/17/20 12:44 PM
RIP Donald Stratton
by 02SE - 02/17/20 12:41 PM
WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Predator35001819, Markapuu, jds59, JimMorrison, bjfangjd
70727 Registered Users
127 registered members (2002 Maxima SE, 2009Caraman, 2013ecof150, 53' Stude, aquariuscsm, AandPDan, 13 invisible), 2,211 guests, and 23 spiders.
Topics301,581
Posts5,198,463
Members70,727
New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change #5210202 09/11/19 01:57 PM
wemay Online Happy OP
OP Online Happy
Screenshot_20190911-155536_Chrome.jpgScreenshot_20190911-155550_Chrome.jpgScreenshot_20190911-155612_Chrome.jpg
2019 VW Passat Wolfsburg TSI
VW High Performance Genuine Engine Oil 0W-20
OEM
2013 Hyundai Santa Fe Sport 2.0T
Shell Rotella Gas Truck 5W-30
OEM
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5210234 09/11/19 02:20 PM
I
Imp4 Online Content
Online Content
I
That's 7300 psi.
Don't let that fail on you catastrophically....
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: Imp4] #5210322 09/11/19 04:12 PM
J
JLTD Offline
J
Originally Posted by Imp4
That's 7300 psi.
Beat me to it...at that pressure a pinhole leak will cut through ... a lot of things.
Lates.
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5210343 09/11/19 04:58 PM
A
A_Harman Online Content
Online Content
A
Common rail diesel systems are running 2000+ bar (29,000 psi).
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5210387 09/11/19 05:52 PM
B
benjy Offline
B
they don't need another problem DI system but both port + DI some are already using!!
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: benjy] #5210451 09/11/19 07:06 PM
1
14Accent Offline
1
As much as I agree, it will never happen. Port + DI is too complex, and costs too much money. I almost wonder why they don't go back to an enrichment-style system, like the early Toyota's and others. A single injector, mounted just behind the throttle body, that sprayed fuel when the engine was cold. In theory, couldn't this single injector be used to momentarily spray an evenly-distributed mist of fuel across the intake valves? That would coat the valves with fuel and break down any deposits that may build up. It wouldn't have to run constantly, just once every few hundred miles under high-load situations where intake velocity is high to aid in deposit removal.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5210594 09/12/19 12:00 AM
N
nthach Offline
N
Toyota is all in on their D-4S system which uses MPI and DI. Ford has licensed the system from Toyota and Denso. Supposedly Mazda figured out how to keep valve deposits at bay.
I can see GM and VW adopting this new Delphi system - given GM's ties to Delphi when it was spun off in the 1990s and VW having to comply with Euro standards which will more than likely clamp down on PM emissions. China, which is one of VW's most important markets also follows Euro specs.
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5210677 09/12/19 05:33 AM
B
BMWTurboDzl Offline
B
Well that's cool. I wonder how many pulses per sec.
435i
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5210866 09/12/19 10:04 AM
OP Online Happy
I've never had deposit issues with any of my GDI vehicles and some have approached 200K miles.
OEM
OEM
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: BMWTurboDzl] #5210867 09/12/19 10:05 AM
OP Online Happy
I was wondering that too.
OEM
OEM
Re: New Delphi 500+ bar GDi system cuts particulates up to 50% without engine change [Re: wemay] #5212436 09/14/19 11:15 AM
N
nthach Offline
N
Mercedes and BMW claim their GDI systems from Bosch or Conti can do up to 5 injection pulses per cycle.
