WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
Removing transferred dye?
by aquariuscsm - 02/17/20 08:53 AM
ST 0W-20 2013 Sienna 100k
by Mangos86 - 02/17/20 08:43 AM
Starter/Generator bearing grease
by puma4440 - 02/17/20 08:04 AM
I Did Buy the 4Runner 3.4 V6 w/253,000 miles
by Speak2Mountain - 02/17/20 07:59 AM
Proper Brake Bleeding Sequence
by Gebo - 02/17/20 07:32 AM
Do new Jeeps have death wobble?
by supton - 02/17/20 07:21 AM
New to me 2014 Passat TDi- T6?
by racin4ds - 02/17/20 07:07 AM
Chemtech Fuel Additive
by momo - 02/17/20 06:36 AM
Hydraulic oil filter cross reference
by shibby6600 - 02/17/20 01:13 AM
War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
JimMorrison, bjfangjd, 45ander5, FlightRT, 74Widebody
70724 Registered Users
97 registered members (4WD, 77GrandPrix, 94astro, 2013ecof150, 1978elcamino, 15 invisible), 2,361 guests, and 24 spiders.
Topics301,561
Posts5,198,113
Members70,724
Page 1 of 3 1 2 3
Leaky just installed new TPMS sensors #5210373 09/11/19 05:36 PM
P
Patrick0525 Offline OP
P
Am I missing something here? Wife’s new Rockauto Denso Sensors are leaking after new tire installation. All 4 tires are leaking where the base of the hex nut contacts the alloy rim via washer. I used soapy water for testing. How can this happen? My wife blames me for the part and the garage I choose to do the install. What a Fisaco!
I give up trying to put new WeatherReady tires and replacing ten old sensors.
2014 Toyota Venza 2GR-FE 96K mi
2009 Lexus ES350 2GR-FE 49K mi
Fram Ultra filter XG9972
TGMO or Idemitsu Zepro 0w20 (winter)
PP 0w20 (spring/summer/fall)
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210374 09/11/19 05:39 PM
bdcardinal Offline
Was the seal installed also?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210376 09/11/19 05:41 PM
JohnnyJohnson Offline
Everyone of these TPMS things is a nightmare. I'll never have them on a car.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Leaky just installed new TPMS sensors [Re: bdcardinal] #5210390 09/11/19 05:53 PM
P
P
The rubber seal is already on the sensor and the plastic bag contained a washer and the hex nut. This is a Lexus ES350.
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210392 09/11/19 05:57 PM
Chris142 Online Content
Online Content
Can you tighten the nut a little more?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210409 09/11/19 06:08 PM
P
P
Is this the additional seal your are referring to
TPMS for Venza
Looks like on the inside there is a seal on the TPMS and then another hat-like seal before it contacts the alloy wheel?
The Venza and the Lexus use the same TPMS sensors.
I have to ask if the hat-like seal was installed or needs to be refreshed.
Re: Leaky just installed new TPMS sensors [Re: Chris142] #5210411 09/11/19 06:11 PM
P
P
Yes, still bubbles present.
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210420 09/11/19 06:21 PM
R
Reddy45 Offline
R
teflon tape or pipe dope?
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210488 09/11/19 07:57 PM
chainblu Online Content
Online Content
I don't see a fix to this without dismounting the tire(s). My first guess would be corrosion that wasn't removed.
Re: Leaky just installed new TPMS sensors [Re: chainblu] #5210619 09/12/19 01:04 AM
P
P
Agree, I will have the technician do a redo and inspect for the corrosion.
Will report back.
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210727 09/12/19 06:57 AM
CapriRacer Offline
Oops, wrong thread!
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210729 09/12/19 06:58 AM
DuckRyder Offline
I had one leak there when I was on the road and needed a tire on the Prius. Tire store insisted on rebuilding the sensor. They tore the gasket installing it and I had to have it fixed by someone competent.
This whole replacing/rebuilding TPMS is nothing but tire shops trying to drum up business. Don’t fix what isn’t broken is my advice. And I’ll forever hold it against that tire store for inconveniencing me and cost me additional money when all they had to do was not mess with it.
I’d bet that is where your problem lies, improper installation of the sensors... Since the don’t fix what isn't broke ship sailed, you’ll probably have to find someone competent, it probably won’t be a tire store.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210783 09/12/19 08:04 AM
Davejam Online Content
Online Content
I get the negativity and feel your pain...
However, on 2 occasions TPMS has helped me recognize leaking tires due to a nail which allowed repair before any issue. So, I appreciate the technology.
I guess report back and maybe we'll know what to do to avoid the situation.
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210790 09/12/19 08:12 AM
G
Gebo Offline
G
I don't know if this will be any help but I learned something about installing them on my Lexus GX470. I purchased the Densos from Amazon ($38 each) after asking my tire dealer. He said they were good. Normally, he won't install TPMS sensors unless you buy them from him. He says people get the wrong ones and it becomes a nightmare for his shop. Before I ordered them, I showed them to my Lexus mechanic and he said they should work fine.
From the get-go about a year ago, that most irritating dash light starting coming on. You know, the one with the tire and the exclamation mark. I have a Blue Driver set up so I just erased the code. My wife complains next month, "That light is on again." I erased the code. Next month, same thing. Of course I am checking the tire pressures in all 5 tires and they are all ok. Light comes on, I erase, light comes on, I erase, etc.
I finally took the GX back to the tire dealer and he said I was gonna have to take my GX back to the Lexus dealer. Matter of fact, the tire dealer has a Lexus and he had to take his back to the Lexus dealer to get the TPMS system to work properly.
My friend is a Lexus mechanic and he said bring it to his house and he would reset all the codes. Dropped it off and he calls the next day and only 3 of the TPMS's will communicate with the GX's computer. So I have 2 that he can code and 3 he can't code.
We talked and I decided to replace all 5 TPMS's with Lexus OEM parts. $68 each (WOW!). It has been two months with no more orange lights on my "wife's" dash. I am hoping my TPMS problems are solved.
I know my results may be very different from any one else's, but I have decided all my TPMS purchases will be from Lexus or Toyota. The hassle was far too great for me (even though I used Denso)
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Leaky just installed new TPMS sensors [Re: Patrick0525] #5210862 09/12/19 10:00 AM
M
madRiver Offline
M
Will report back.
Do you pay him more labor since this a labor only job and you are holding the bag for the provided parts? Hope it works out.
Page 1 of 3 1 2 3
