WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
Removing transferred dye?
by aquariuscsm - 02/17/20 08:53 AM
ST 0W-20 2013 Sienna 100k
by Mangos86 - 02/17/20 08:43 AM
Starter/Generator bearing grease
by puma4440 - 02/17/20 08:04 AM
I Did Buy the 4Runner 3.4 V6 w/253,000 miles
by Speak2Mountain - 02/17/20 07:59 AM
Proper Brake Bleeding Sequence
by Gebo - 02/17/20 07:32 AM
Do new Jeeps have death wobble?
by supton - 02/17/20 07:21 AM
New to me 2014 Passat TDi- T6?
by racin4ds - 02/17/20 07:07 AM
Chemtech Fuel Additive
by momo - 02/17/20 06:36 AM
Hydraulic oil filter cross reference
by shibby6600 - 02/17/20 01:13 AM
War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
JimMorrison, bjfangjd, 45ander5, FlightRT, 74Widebody
70724 Registered Users
109 registered members (allepunta, 2013ecof150, 1978elcamino, alchargo, AandPDan, 14 invisible), 2,402 guests, and 18 spiders.
Topics301,560
Posts5,198,107
Members70,724
Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... #5209197 09/10/19 11:14 AM
G
GM4LIFE Offline OP
G
I took a sample from my 2019 CTS-V with just under 5K miles. I changed the factory fill at 1,890 miles and went with the new 2019 Corvette spec Mobil 1 0W40 ESP. This is NOT the M1 0W-40 Euro formula. So far looks good after 3K miles with a TBN at 5.1, so will run it for at least 5K miles between change intervals. This oil seems to be good according to Blackstone labs. M1 developed it specifically for the Corvette LT1/LT4/LT5 engines.
[Linked Image from i541.photobucket.com]
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209243 09/10/19 12:33 PM
B
BMWTurboDzl Offline
B
Hate to break it to you. You can't draw any conclusions on an engine with less than 50k miles let alone 5k miles.
435i
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209293 09/10/19 01:38 PM
G
GZRider Offline
G
Awesome car! Good luck with it. Beyond that the good BMWTurboDzl is pretty much correct, it's unlikely for such early UOA's to reveal anything about engine wear other then new engines break in. You can save your money for the gas and insurance, you're gonna need it!
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209320 09/10/19 02:11 PM
G
GM4LIFE Offline OP
G
Thanks guys!
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209334 09/10/19 02:25 PM
B
Bjornviken Offline
B
try another oil
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: Bjornviken] #5209345 09/10/19 02:40 PM
G
GM4LIFE Offline OP
G
Originally Posted by Bjornviken
try another oil
Not many oil choices for the 2019 Corvette model year. This is it.
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209425 09/10/19 04:00 PM
A
A_Harman Online Content
Online Content
A
Stay with the M1 0w40 ESP. Iron wear looks pretty low for an engine still breaking in, but since you dumped the factory fill early, maybe you got rid of the break-in debris.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: A_Harman] #5209431 09/10/19 04:09 PM
G
GM4LIFE Offline OP
G
I stocked up on the new M1 0W-40 ESP, so I have plenty on the shelf. I always like to dump the factory fill around 1500-2000 miles as you never know what oil is used from the factory and I like to get all the initial break-in debris out as soon as possible. This engine feels especially powerful over the other LT4s I have had so far. I will keep using this new formula as long as I have it.
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209442 09/10/19 04:20 PM
demarpaint Offline
I'd stay with the ESP as well. IMO it is one of the best offerings from XOM.
God Bless Our Troops
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209459 09/10/19 04:50 PM
B
buster Offline
B
I would definitely stick with the ESP 0w40. XOM and GM did 2 years worth of testing with it. I think they know best.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209563 09/10/19 07:04 PM
B
buster Offline
B
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5209905 09/11/19 07:20 AM
B
buster Offline
B
...aeration was a big factor in the development of this oil.
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5210063 09/11/19 10:51 AM
R
rrounds Offline
R
I thought a 40w could not be lower that 12.5 nor higher than 16.2 ? if so is the 11.99 this oil shows in just 3000 miles telling us something.
Rod
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5210133 09/11/19 12:12 PM
B
buster Offline
B
This has been a characteristic of M1 0w40 for years. I believe it is designed this way. It's always hovered around 11.5 - 13cSt. It should be of no concern the oil has probably been tested in more high performance applications than any oil in the world.
Re: Mobil 1 0W-40 ESP, 2019 CTS-V, 3,000 Miles... [Re: GM4LIFE] #5210555 09/11/19 09:37 PM
SteveG4 Offline
Nice ride and a great oil. I'd stick with it.
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
