2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
Jimbobert56, Ollie_B_2000, akarip, BJD2020, ToyTaco2002
70803 Registered Users
117 registered members (1978elcamino, 28oz, AlaskaMike, 4WD, aba4430, 9 invisible), 2,056 guests, and 18 spiders.
Topics301,945
Posts5,205,994
Members70,802
98 Olds 88 V6 3800...steering wheel issue #5210398 09/11/19 06:01 PM
M
Mark72 Offline OP
M
So when I turn right I hear and feel a pop in the steering column. Usually when I turn right. Sometimes I hear it when I turn left. My mechanic said there is a boot in there that could be torn. Is this an issue that needs immediate attention? Is what my mechanic suggested likely what the problem is?
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210404 09/11/19 06:05 PM
M
mk378 Online Content
Online Content
M
Seems more likely it's a bad joint, loose bolt, or other actual mechanical problem. Yes this sort of thing needs to be checked immediately. There are places in the steering system for a single point of failure to cause loss of control of the car.
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210407 09/11/19 06:07 PM
J
JLTD Offline
J
Some models have a U-joint in the steering column. Sounds like yours may be going bad. Not critical, until the day it snaps and leaves you without steering. Time to save up for the repair IMO.
Lates.
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210448 09/11/19 07:01 PM
1
14Accent Offline
1
It could be any number of things, steering joint included. However, I've never ever seen a steering joint in an H-body fail. Ever. I would put my money on a suspension component that's sending feedback through the wheel. Can you recreate the feeling while stationary? Have a helper turn the wheel while you put your hand on the front coil springs. If you feel a popping, you've got sticking upper strut bearings. Also check the front end for broke sway bar end links/a broken bar. Neither is uncommon, and will create a popping noise when the weight shifts from side to side.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: mk378] #5210479 09/11/19 07:48 PM
I
Ihatetochangeoil Offline
I
I'm going to second this, and add that I've been driving GM H-bodies since 1994, and I currently own 3 nicely running Buick Lesabres. Your "problem" isn't a torn boot; rubber boots don't go "pop" when you turn right. https://www.youtube.com/results?search_query=gm+h+body+popping+when+turn+right
Whatever
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210536 09/11/19 09:08 PM
T
tahoe_hybrid Offline
T
I had this happen on my Wbody my mechanic said a bolt was missing causing it he said the wheel could have flew off.. while driving
I think the transmission shop that worked on it had an extra bolt left smirk2]
he found the problem on the spot..
miss him he passed away earlier this year frown frown frown
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210564 09/11/19 09:57 PM
Nick1994 Offline
Is it a locking steering column?
Might be the locking pin behind the steering wheel. Don't put the keys in the ignition, see if the wheel turns.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210688 09/12/19 05:47 AM
dadto2 Offline
I know that this is a completely different car, but... I had the same problem on my Volvo S70. It was a bad ball joint. Once I replaced the ball joint, the "pop" in the steering disappeared.
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210741 09/12/19 07:15 AM
supton Online Content
Online Content
Interesting; I have a similar pop, but it's when I'm going left. I'm not able to recreate it in the parking lot though--it appears I have to be moving, just sawing the wheel back and forth doesn't make the pop.
I've been ignoring it for the last year as I've figured it was either the strut bearing and/or it'd get worse and then be easy to find. But a friend of mine recently lost a balljoint: his car steered into a tree and totaled itself before he could react.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210812 09/12/19 08:46 AM
Online Content
FWIW I just looked at mine, using this link. I'm not sure how much force needs to be used on the 2x4, nor if it should be replicated with the wheels straight ahead and then turned left and then right; but I didn't find any slop in anything on mine.
And of course, while on jackstands, no noise can be heard...
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210951 09/12/19 12:03 PM
M
Online Content
M
If it happens only when the car is moving, check the sway bar and links. You can also push on the car while it is parked to rock it side to side to see if it is related to one side going up and down.
With any suspension noise it often helps to be listening outside when it happens, have someone drive past you and do what needs to be done to make the noise.
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5210964 09/12/19 12:17 PM
L
Lubener Offline
L
Many times a poping is caused by faulty CV joints, especially if a boot has torn.
The "thinking" man's friend.
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5211260 09/12/19 09:01 PM
M
Mark72 Offline OP
M
Sorry I didnt reply sooner. This pop sound I hear is not a ball joint or any component by the wheels. It is right behind the dash where the steering column is.
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5211378 09/13/19 03:52 AM
L
Lubener Offline
L
This is why so many repairs are attempted unsuccessfully- "failure to communicate".
Re: 98 Olds 88 V6 3800...steering wheel issue [Re: Mark72] #5211442 09/13/19 05:57 AM
M
Mark72 Offline OP
M
Very true. But with that.. Any ideas why the steering column would make a pop sound when I turn? When I asked my mechanic he said there is a boot in there and a joint that is greased and sometimes those go bad. I just wanted to mention this issue here on the forum to see if any of you have any thoughts on this.
