Forums Migration
Please read this thread
EP additive?
by CCI - 07/10/20 11:06 PM
Kawa FR600V Oil
by Propflux01 - 07/10/20 10:34 PM
Dexron VI for 700R4.
by jakewells - 07/10/20 10:22 PM
Picked Up the DeWalt Mid Range Impact
by Fringe - 07/10/20 09:42 PM
Checking out neighbours lawn mower
by Snagglefoot - 07/10/20 09:19 PM
TV help needed
by ffhdriver - 07/10/20 09:00 PM
FS Solar panels PU only 250w $80
by BeerCan - 07/10/20 08:29 PM
Ford Easy Fuel
by buck91 - 07/10/20 08:27 PM
Oil for the track
by lowon - 07/10/20 07:34 PM
Bought a grapple
by Ausfahrt - 07/10/20 06:30 PM
What is this charger for?
by CharlieJ - 07/10/20 05:58 PM
World War II movie Greyhound
by skyactiv - 07/10/20 05:48 PM
GC for Fuel Dilution - Accuracy
by Gene K - 07/10/20 05:21 PM
How Do I Get This On?
by Gebo - 07/10/20 05:08 PM
Creativity Suggestions?
by maverickfhs - 07/10/20 03:18 PM
3.5 Ecoboost Oil, I've decided.
by Gene K - 07/10/20 02:07 PM
Mopar Extended Warranty with 100% Refund Option
by The Critic - 07/10/20 12:46 PM
The great lakes are warm!
by OVERKILL - 07/10/20 11:38 AM
SUmeme22, DaveCaddell, SharkNC, Puckster02, TurbodogTodd
71907 Registered Users
43 registered members (ammolab, 77GrandPrix, alcyon, BigCahuna, ajchien, 3 invisible), 1,055 guests, and 30 spiders.
Topics307,708
Posts5,316,194
Members71,907
Page 3 of 7 1 2 3 4 7
Re: Engine Break-In - Found the answer [Re: buster] #5210104 09/11/19 12:31 PM
DGXR Offline
Porsche engineer's statements contradict the ages-old method of doing a few full heat cycles, this is probably adapting to modern manufacturing and engineering principles. I keep moderate loads and varying RPM during the first few hundred miles, doing an early oil change, then gradually increasing to maximum power and redline runs at around 2,000 miles.
Deceleration (i.e. high vacuum in intake manifold and cylinders) plays a crucial role during the wear-in process.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: Engine Break-In - Found the answer [Re: buster] #5210105 09/11/19 12:31 PM
B
buster Offline OP
B
For the Nissan, the truck already had 63 miles on it. I was told the test drives are all the same (same one I went on), in which case there is little room for abuse. From the time I picked up the truck to present, I did all short trip/stop and go type driving. I kept rpms between 2k and 4k. I may have hit 5k once. Today I hit Nissan's 1,200 mile break-in mark and did 2 WOT's. At this point what is done is done. I saw no noticeable oil consumption the first 1k miles. EDGE has been in the last 200 miles.
I'm glad I came across this article though. It was the only article (FWIW) where an actual automotive engineer gave some insight into "why" they recommend not exceeding 4k. Like most things in life, moderation is often the best bet.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Engine Break-In - Found the answer [Re: DGXR] #5210115 09/11/19 12:50 PM
CT8 Offline
How do diesel engines break in? I worked at a forklift dealership that leased forklifts, fleet cars, vans, pickups and class 8 vehicles . Engines break in fine without any voodoo. Travis ' post is gospel.
2015 F150 2.7
2018 F350 6.2
Re: Engine Break-In - Found the answer [Re: KrisZ] #5210158 09/11/19 01:57 PM
L
LoneRanger Offline
L
Originally Posted by KrisZ
Originally Posted by buster
With what we know, I will say that lugging the engine is far worse than a few WOT's.
Yes, I agree. I would also add compression braking as a benefit.
And with today's wide spread ratio automatics and CVTs, many engines not only spin at very low RPM, but they also don't do any compression braking, unless in sport mode or manually prompted.
Generally referred to as "vacuum pulls." If you can find a road with lots of foot hills and slip the automatic transmission into sport mode or manual mode so it rows down through the gears on decel and engine brakes, that is the Shining City on a Hill to strive for, for nice break-in runs. Goose it up the grade, let Sport Mode engine brake it on the down hill side. Lather, rinse, repeat. Living in the flat lands, could not find such a stretch of road for the GMC and F-150, had to settle for acel/decel runs on long sparsely driven flat roads, a certain stretch of a particular county road saw a lot of our two new vehicles this spring and summer.
Re: Engine Break-In - Found the answer [Re: LoneRanger] #5210163 09/11/19 02:06 PM
B
buster Offline OP
B
thumbsup
South Jersey is pretty flat too. I'd have to go up to centra/north Jersey or Pennsylvania to find hills.
Re: Engine Break-In - Found the answer [Re: buster] #5210216 09/11/19 03:10 PM
L
loneryder Offline
L
I can imagine how frustrating for a new Porsche owner to have to baby it for 2k miles. When I bought my new Harley at Black Hills HD, it was really hard to vary the engine speeds on those wide open roads out there. I was on the 4 lane road going out of Rapid City to Mt. Rushmore. I had been driving the speed limit for a while and it was time to "vary the speed". I was going about 45 and cars were passing me looking at me like I was crazy. Very un natural.LOL
Re: Engine Break-In - Found the answer [Re: CT8] #5210377 09/11/19 06:41 PM
A
A_Harman Offline
A
The old German who was chief of cylinder kit engineering at Cummins when I worked there swore that if a new diesel engine was not ramped up to full power within 20 minutes of first start, it would not break in properly.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Engine Break-In - Found the answer [Re: ARCOgraphite] #5210382 09/11/19 06:44 PM
W
willbur Offline
W
Non pressure fed IMS bearing had nothing to do with it. Undersize bearings that could not handle the load was the culprit. Many Porsche owners changed oil at the recommended OCI of 15K miles which let acid accumulate and eat those undersize bearings, too. Toyota actually designed that car! Porsche needed help to stay alive and asked them to help. Strange world.
Re: Engine Break-In - Found the answer [Re: CT8] #5210402 09/11/19 07:05 PM
Chris142 Online Content
Online Content
How do diesel engines break in? .
I used to get to bring brand new trucks to the yard. I would ride to vegas or Laughlin,NV with another driver. I would take possession of the truck there (saved on California taxes). I would drive over to the yard they had in NV. Hook to a set of trailers ,load them to the max legal 80000lbs and bring it home.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Engine Break-In - Found the answer [Re: buster] #5210659 09/12/19 06:06 AM
P
PWMDMD Offline
P
The real question - does any of the break-in procedure really matter in the real world? I've owned many many cars from many many manufactures and I have never followed the break-in procedure. I drive the cars, I've never had an engine/transmission/moving part give me an issue related to improper break-in, I sell the car and I get a new car.
Current: 2020 Toyota Tundra Platinum (PP 0W-20 and Toyota OEM Filter) and 2019 Lexus RX 350 (PP 0W-20 and Toyota OEM Filter)
Re: Engine Break-In - Found the answer [Re: PWMDMD] #5210669 09/12/19 06:23 AM
B
buster Offline OP
B
That’s the million dollar question. We don’t know.
Re: Engine Break-In - Found the answer [Re: PWMDMD] #5210670 09/12/19 06:25 AM
B
BMWTurboDzl Offline
B
Poor break-in can result in oil consumption and/or the engine will not reach its full potential. The first you'd notice but the vast majority if owners would not notice the second.
Of course there's engine break-in, there's vehicle break-in and finally driver break-in (I added this piece).
435i
Re: Engine Break-In - Found the answer [Re: BMWTurboDzl] #5210697 09/12/19 06:58 AM
B
buster Offline OP
B
Are you in the break it in hard camp?
Re: Engine Break-In - Found the answer [Re: buster] #5210796 09/12/19 09:22 AM
B
BMWTurboDzl Offline
B
Hard / Soft is somewhat subjective.
I'd best describe it as methodical engine loading during both acceleration and deceleration across the rpm range while for the most part staying within the max rpm suggested by the automaker.
435i
Re: Engine Break-In - Found the answer [Re: DGXR] #5210799 09/12/19 09:26 AM
B
BMWTurboDzl Offline
B
Right but can you imagine the potential liability by recommending such a thing? "Porsche said I should break-in my engine by downshifting, I didn't know that downshifting into 3 at 80 mph would cause engine damage! My $500/hr attorney is going to have a field day with this."
435i
