QS Conv vs. QS HM vs. PYB
by Fordiesel69 - 02/17/20 01:09 PM
Kia Proceed?
by WhyMe - 02/17/20 12:44 PM
RIP Donald Stratton
by 02SE - 02/17/20 12:41 PM
WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
Removing transferred dye?
by aquariuscsm - 02/17/20 08:53 AM
ST 0W-20 2013 Sienna 100k
by Mangos86 - 02/17/20 08:43 AM
Starter/Generator bearing grease
by puma4440 - 02/17/20 08:04 AM
I Did Buy the 4Runner 3.4 V6 w/253,000 miles
by Speak2Mountain - 02/17/20 07:59 AM
Proper Brake Bleeding Sequence
by Gebo - 02/17/20 07:32 AM
Do new Jeeps have death wobble?
by supton - 02/17/20 07:21 AM
New to me 2014 Passat TDi- T6?
by racin4ds - 02/17/20 07:07 AM
Chemtech Fuel Additive
by momo - 02/17/20 06:36 AM
Hydraulic oil filter cross reference
by shibby6600 - 02/17/20 01:13 AM
jds59, JimMorrison, bjfangjd, 45ander5, FlightRT
70725 Registered Users
103 registered members (Alfred_B, 1978elcamino, aquariuscsm, ArrestMeRedZ, 94astro, 8 invisible), 2,511 guests, and 21 spiders.
Topics301,568
Posts5,198,177
Members70,725
Need grease that's safe to be around gear oil #5210113 09/11/19 11:46 AM
T
that_guy318 Offline OP
T
I'm replacing some bearings in the transmission of my car (Porsche 928) that got ruined from moisture and lack of lubrication. They're needle bearings that ride between the input and main/output shaft of the transmission.
There isn't much splash lubrication getting to these due to their location, so I'm wanting to pack these with some grease to prevent this from happening again. I'll be running mobil delvac 75w90 gear oil in the trans. What grease would be safe to possibly have some gear oil splash on it and not hurt things if some did wind up mixing with the gear oil?
-99 Durango 5.2L V8 178k miles
Castrol GTX High Mileage 10w30 with Purolator/Mopar filter every ~3,500 miles
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210174 09/11/19 01:19 PM
J
Jimzz Offline
J
Generally you use Vaseline, or other low melting temp grease, when installing needle bearings in manual transmissions.
That way when it warms up, the grease will melt off and not clog up any passages or block the oil from flowing.
yup
Re: Need grease that's safe to be around gear oil [Re: Jimzz] #5210190 09/11/19 01:41 PM
CT8 Online Content
Online Content
+1 on the Vasaline. Redline oil and others make engine assembly greases that have a low melting points if you want to go exotic as compared to the vasoline.
2015 F150 2.7
2018 F350 6.2
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210198 09/11/19 01:53 PM
T
T
I don't want assembly grease though, I want something that will continuously provide lubrication to these parts because they are not being sufficiently lubricated otherwise.
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210263 09/11/19 02:36 PM
M
mk378 Offline
M
Does the spec call for 75W90? Most car manual transmissions use a lighter oil or manual transmission fluid, which is not traditional gear oil.
Re: Need grease that's safe to be around gear oil [Re: mk378] #5210293 09/11/19 03:32 PM
T
T
Yes it calls for 75w90 gl5.
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210296 09/11/19 03:41 PM
CT8 Online Content
Online Content
You could try a sealed bearing.Does the car sit and sit or is it a driver?
2015 F150 2.7
2018 F350 6.2
Re: Need grease that's safe to be around gear oil [Re: CT8] #5210499 09/11/19 08:03 PM
T
T
Different bearings aren't an option, they aren't a standard size. The car gets driven a couple times a week. There just isn't much oil getting to these hence the want for grease for them.
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210541 09/11/19 09:16 PM
H
HorseThief Offline
H
Park your car on an incline or drive up lots of hills? shrug
Problem solved....
I saw a brown dog
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210777 09/12/19 08:01 AM
T
T
So noone knows of a grease that is safe to be around gear oil?
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210821 09/12/19 08:57 AM
MolaKule Offline
Global Moderator
Global Moderator
What year Porche?
As stated by others, there is no grease that will not be dissolved by the gear oil. I.e, it will not stay in place without becoming part of the gear lube.
Splash lubrication will eventually wash off any grease, period.
If your tranny's gear oil somehow accumulated a lot of moisture that thinned out the lube and oxidized the gear lube, then you need to mitigate the moisture problem.
Does this transmission have a breather tube?
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210843 09/12/19 09:29 AM
I
ironman_gq Offline
I
Did a little digging around and I found a bunch of guys that mix wheel bearing grease with gear oil in truck hubs without any issues. I'd avoid anything lithium or moly but I guess I don't know why disc brake wheel bearing grease couldn't work. I know that I've used it to hold roller bearings in place when rebuilding a couple transmissions and transfer cases
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5210909 09/12/19 11:09 AM
T
T
I think I'll give that a try with the wheel bearing grease.
The whole problem here again is that there isn't much splash lubrication getting to these bearings. So the little bit of grease that I'm going to put on them probably isn't going to get much oil trying to wash it away, and if it does eventually it's because it got some oil to it.
Re: Need grease that's safe to be around gear oil [Re: that_guy318] #5211744 09/13/19 11:39 AM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by molaKule
What year Porche?
Some questions have been asked and it would be simply a matter of courtesy if you could answer those questions.
