Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
California, all trucks commercial vehicles
by Redright9 - 05/27/20 09:47 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
32 registered members (bsmithwins, BrianF, blufeb95, 928, 2009Caraman, 2 invisible), 1,477 guests, and 27 spiders.
Topics305,955
Posts5,283,622
Members71,545
Oils wothout Moly? #5209950 09/11/19 09:14 AM
Y
yowps3 Offline OP
Y
Theortically are there too many drawbacks of having 0 ppm molybdenum?
Does Moly have any disadvantages?
Re: Oils wothout Moly? [Re: yowps3] #5209968 09/11/19 09:25 AM
Quattro Pete Offline
https://www.bobistheoilguy.com/moly-basics/
Moly is typically used as anti-wear agent, but there are other anti-wear agents that may be used instead, such as titanium, boron, zinc. So, there is more than one way to skin the cat.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Oils wothout Moly? [Re: yowps3] #5209983 09/11/19 09:50 AM
B
burla Offline
B
For the longest time Valvoline and Royal Purple didn't have moly, amoung a few others, but the uoa's did not suffer, especially with valvoline. But I cann tell first hand high moly is beneficial, many ticks have been killed with it, not only in high moly oils but additives as well.
Re: Oils wothout Moly? [Re: yowps3] #5210032 09/11/19 11:16 AM
J
jbutch Offline
J
Many HDEO have 0 moly and yet they have excellent uoas. Usually, like Quattro Pete said, there are other AW that acts similarly.
People seems to focus a lot on moly content, but an oil formulation has to be looked at as a whole and not focus on one of the many ingredients.
That being said, some researches came to conclusion that moly might help timing chain wear, but so does boron.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Oils wothout Moly? [Re: yowps3] #5210054 09/11/19 11:40 AM
A
aquariuscsm Offline
A
Oils with high moly content are legendary for making engines smooth and quiet.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Oils wothout Moly? [Re: yowps3] #5210055 09/11/19 11:40 AM
Z
zeng Offline
Z
Moly works as a solid lubricant/AW that performs 2 main function :
a )To reduce Coefficient of Friction (in mixed and boundary lubrication regimes), hence enhancing fuel economy with reduced frictional heat generation , and
b )Enhance MOFT as a solid lubricant and/or AW.
It's sort of a 'requirement' in FE low viscosity CAFE oils like xW16 and xW20 etc , not so in mineral normal viscosity grades oils like 15W40 or 20W50.
Re: Oils wothout Moly? [Re: jbutch] #5210075 09/11/19 12:06 PM
DGXR Offline
Exactly! This reminds me of all the threads that obsess over base oils, that one oil is better than another simply because of the base oil content. Ha. Each oil producer additive packages have many different chemical substances in different quantities, with the goal being a complete package (antiwear, low volatility, resistance to oxidation and shear and other breakdown, all that stuff). Zero moly means nothing because the performance of the finished lubricant product is what matters. Thank you jbutch.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Oils wothout Moly? [Re: yowps3] #5210100 09/11/19 12:26 PM
M
Mad_Hatter Offline
M
You can't conclude a lube is rubbish simply because it lacks moly. It just depends on how they balance everything (phos/zinc/film strength) synergistically, whether or not they choose to use moly. Some formulas might prefer boron for example, because it also contributes in other ways to the lube.
Re: Oils wothout Moly? [Re: yowps3] #5210129 09/11/19 01:07 PM
K
kschachn Offline
K
So does Kixx oil have molybdenum or not? Which way are you going here?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Oils wothout Moly? [Re: kschachn] #5210175 09/11/19 02:21 PM
M
Mad_Hatter Offline
M
It is a strangely worded question, almost a loaded question.
Re: Oils wothout Moly? [Re: yowps3] #5210191 09/11/19 02:42 PM
B
burla Offline
B
The great thing is there are choices for both, if you don't want moly there are oils for you, if you want some moly there are oils for you and if you want a boat load of moly there are oils for you. Read the paper out there make a choice, done.
Re: Oils wothout Moly? [Re: yowps3] #5210224 09/11/19 03:14 PM
R
Railrust Offline
R
I think the biggest surprise to me was when Valvoline for years had almost zero moly, to making a dramatic change last year to having it. Wonder what caused that change?
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Oils wothout Moly? [Re: Railrust] #5210238 09/11/19 03:22 PM
P
PandaBear Offline
P
SN+, LSPI issue with high calcium and one known answer is to replace a lot of calcium with a little moly.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Oils wothout Moly? [Re: PandaBear] #5210345 09/11/19 06:02 PM
A
A_Harman Offline
A
Valvoline going away from the 440 ppm Sodium additive pack was a bigger surprise to me.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Oils wothout Moly? [Re: kschachn] #5210503 09/11/19 09:07 PM
SteveG4 Offline
Mikey likes it!
Err... no, that's Kix.
crazy
Somewhere between Alaska and Wisconsin...
2006 4WD Silverado LT Crew Cab & 2013 AWD Equinox
