Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
38 registered members (bbhero, carviewsonic, Bailes1992, bachman, Arrechera, 53' Stude, 4 invisible), 761 guests, and 17 spiders.
Topics301,815
Posts5,203,205
Members70,784
Page 2 of 2 1 2
Re: Anyone used valvoline restore? [Re: Mad_Hatter] #5210056 09/11/19 10:44 AM
Donald Offline
Originally Posted by Mad_Hatter
Originally Posted by Donald
You need to do a compression test to see if you can figure out which set of rings have the issue. The compression rings or oil control ring. Worn valve stem seals show up as oil burning at startup after sitting for several hours.
A fuel additive may help with compression rings. And an oil additive with the oil control rings.
Cold engine yes but idling and off throttle braking can result in increased manifold pressure which can draw oil past worn valve stem seals.
You could compression test the cylinders but you know it's not gonna have great compression since it's consuming oil. Unless you're willing to plunk down the cash, in the event of really bad readings, to replace the rings, I'm not sure the ROI is favorable on a compression test.
Symptoms of bad valve stem seals
Originally Posted by buster
If the rings are worn, this oil won't help. If they are stuck or dirty, it will.
+1
I believe you can have pretty good compression and still burn oil. If all that wrong is the oil control ring (gunked up), you will burn oil but still have pretty good compression.
2015 Ford F-250 w/Powerstroke
Re: Anyone used valvoline restore? [Re: Donald] #5210081 09/11/19 11:10 AM
M
Mad_Hatter Offline
M
Ok yeah, I suppose that is possible. Good point..👍
Re: Anyone used valvoline restore? [Re: D1dad] #5210228 09/11/19 02:19 PM
SubieRubyRoo Offline
If you did the Kreen soak as prescribed (1 oz in each cylinder, sit overnight), a pint in the crankcase, and the rest in the gas tank and you didn't see any improvement, then Restore isn't going to fix your problem. If you didn't do the Kreen soak as they recommend, I'd either do it again or try Restore. But Kreen is much cheaper and much stronger for a quicker response.
De omnibus dubitandum.
Re: Anyone used valvoline restore? [Re: D1dad] #5210255 09/11/19 02:32 PM
Char Baby Online Content
Online Content
Check/replace the PCV.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Anyone used valvoline restore? [Re: D1dad] #5210291 09/11/19 03:29 PM
diyjake Offline
If you do end up trying Restore, please let us know the outcome.
Page 2 of 2 1 2
