Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
38 registered members (53' Stude, bbhero, claluja, carviewsonic, Char Baby, Bailes1992, 4 invisible), 777 guests, and 17 spiders.
Topics301,815
Posts5,203,206
Members70,784
Anyone used valvoline restore? #5209790 09/11/19 04:46 AM
D1dad Offline OP
My Cummins dealer has it in stock. Yes it’s expensive but if it would actually free the rings in my 09 altima oil burner then it’s worth it. I’ve searched the site without finding any real testimony.
Re: Anyone used valvoline restore? [Re: D1dad] #5209791 09/11/19 04:49 AM
B
buster Offline
B
I'd give it a shot. This oil was designed to clean. I believe it's 50% POE.
Last edited by Kestas; 09/11/19 05:07 AM. Reason: No need to completely quote the first post in the second post.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Anyone used valvoline restore? [Re: D1dad] #5209798 09/11/19 05:11 AM
K
khittner Offline
K
I’ve tried it once in my ‘02 Camry’s 2AZ-FE. Not a lot of difference after a 5K-mile OCI—I’m still burning a quart every 1200 miles, or so. My engine has 286K on it, though, and I’m taking several mechanics’ advice to just keep it topped off, and keep on driving.
Re: Anyone used valvoline restore? [Re: D1dad] #5209800 09/11/19 05:12 AM
D1dad Offline OP
Anyone see an issue running it in an engine that calls for 5-30? I’ve been running PP 10-30 for a few oil changes because meijer was closing it out at $6 a jug so I bought all they had. Unfortunately the PP did little to slow down consumption, 3/4 of a quart every thousand or so miles. The car is nothing if not consistent since I bought it new.
Re: Anyone used valvoline restore? [Re: khittner] #5209801 09/11/19 05:14 AM
D1dad Offline OP
Good to know and pretty much where I’m at but only 112k. Cars never give me an ounce of engine issues outside of oil consumption.
Re: Anyone used valvoline restore? [Re: D1dad] #5209804 09/11/19 05:16 AM
demarpaint Offline
I would use it in a vehicle that calls for 5W30.
God Bless Our Troops
Re: Anyone used valvoline restore? [Re: D1dad] #5209824 09/11/19 05:43 AM
M
Mad_Hatter Offline
M
If it's tired worn rings there's not much you can do short of replacing them but if it's stuck rings (heavy carbon deposits keep the ring from standing out, staying stuck in the groove) you can try freeing them by using an engine flush or fuel additive designed to clean deposits. You could also be consuming oil via worn valve stem seals.
Other than that I'd use the highest viscosity, synthetic HiMi (for the addtl SCA's) oil i could, with the highest flash point to keep loss to a minimum... and keep topping off.😉
Re: Anyone used valvoline restore? [Re: D1dad] #5209867 09/11/19 06:34 AM
Donald Offline
You need to do a compression test to see if you can figure out which set of rings have the issue. The compression rings or oil control ring. Worn valve stem seals show up as oil burning at startup after sitting for several hours.
A fuel additive may help with compression rings. And an oil additive with the oil control rings.
2015 Ford F-250 w/Powerstroke
Re: Anyone used valvoline restore? [Re: D1dad] #5209869 09/11/19 06:38 AM
K
khittner Offline
K
Hmm. Is yours a 2AZ-FE? If so, at that mileage, I think I’d take the big gulp and do the prescribed piston & ring replacement, if you like the car. Mine has never been apart, aside from a valve cover gasket replacement several years ago, and the mechanic said it still had 95+% of its OE compression after a leak down test.
Re: Anyone used valvoline restore? [Re: D1dad] #5209890 09/11/19 07:06 AM
B
buster Offline
B
If the rings are worn, this oil won't help. If they are stuck or dirty, it will.
Re: Anyone used valvoline restore? [Re: D1dad] #5209900 09/11/19 07:15 AM
M
Mad_Hatter Offline
M
Cold engine yes but idling and off throttle braking can result in increased manifold pressure which can draw oil past worn valve stem seals.
You could compression test the cylinders but you know it's not gonna have great compression since it's consuming oil. Unless you're willing to plunk down the cash, in the event of really bad readings, to replace the rings, I'm not sure the ROI is favorable on a compression test.
Symptoms of bad valve stem seals
+1
Re: Anyone used valvoline restore? [Re: D1dad] #5209907 09/11/19 07:22 AM
A
A_Harman Offline
A
I'd give the Restore a try. I think Restore is $73 a gallon, and that's a lot cheaper than a ring job.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Anyone used valvoline restore? [Re: D1dad] #5209938 09/11/19 08:01 AM
K
krismoriah72 Offline
K
Here is an alternative... Kreen.. from a respected poster here..
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1940735
Re: Anyone used valvoline restore? [Re: krismoriah72] #5209951 09/11/19 08:14 AM
K
khittner Offline
K
Been there, done the Kreen piston soak. No difference.
Re: Anyone used valvoline restore? [Re: D1dad] #5209984 09/11/19 08:51 AM
Astro14 Offline
You bring up several issues...
First, if it's been burning 3/4 every thousand since new - your rings aren't stuck, this is just an oil burner. I doubt you'll see any change. Loose rings from the factory? Bad valve guide clearance from day one? Some engines just use oil, and it appears that this is one of them. If you want the oil burning to stop, you're going to need mechanical repair, new rings at least.
As far as using a 10W30 in a 5W30 engine, no worries. It won't hurt a thing. Even in Ohio.
Personally, I would give it a shot. Who knows?
If it doesn't work, keep looking for oil on sale and keep topping off. I wouldn't invest thousands in mechanical repair for a 10 year old car that could be totaled or traded in tomorrow. It's worth the same on the used market whether it burns oil or not. So, I would find oil on sale, keep it topped off, and live with it as is...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
