Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
84 registered members (4WD, bbhero, bdcardinal, Aichiguy, 2010Civic, AZjeff, 7 invisible), 1,476 guests, and 18 spiders.
Topics301,809
Posts5,203,141
Members70,784
Automatic transmission vent hose #5209760 09/11/19 02:39 AM
O
OilUzer Offline OP
O
Do all sealed automatic transmissions have a breather or vent hose and does it have a valve?
Re: Automatic transmission vent hose [Re: OilUzer] #5209765 09/11/19 03:04 AM
T
tahoe_hybrid Offline
T
the dip stick is the vent (if it has one)
Re: Automatic transmission vent hose [Re: OilUzer] #5209769 09/11/19 03:35 AM
Skippy722 Online Happy
Online Happy
There has to be one otherwise pressure would build up inside the transmission. And yes, there is usually a valve of some sorts, usually just keeps the bigger schmoo out.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Automatic transmission vent hose [Re: OilUzer] #5209818 09/11/19 05:33 AM
A
aquariuscsm Offline
A
My Accord has one on top next to the dipstick with a rubber cap on it.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Automatic transmission vent hose [Re: Skippy722] #5209832 09/11/19 05:58 AM
E
EricG Offline
E
No, some are open vents example GM 4L60 and 4L80, some have check valves in the vent caps example Ford 6R80!
11 F150 4x4 5.0
11 Cadillac SRX
03 Century
l
Re: Automatic transmission vent hose [Re: OilUzer] #5209975 09/11/19 08:33 AM
L
LotI Offline
L
My new Buick(Opel) has the vents for the transmission and AWD transfer case zip-tied to the coolant bottle.
[Linked Image]
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: Automatic transmission vent hose [Re: OilUzer] #5210276 09/11/19 02:52 PM
P
PandaBear Offline
P
It is a must. My dad's 01 Taurus had a huge amount of ATF burped on the garage floor, because the vent is too short and was stuck. TSB said pull the old one out and hammer in a barb and use hoses to build a snorkel to the top. It works fine ever since, no more burping.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Automatic transmission vent hose [Re: OilUzer] #5210278 09/11/19 02:56 PM
L
LeakySeals Offline
L
The front diff vent tube fell off its wheel well post in my 06 Escalade during winter. A months worth of cooling down and warming up cycles sucked in enough salt water and sand to grenade the diff. So yeah, breathers are critical.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Automatic transmission vent hose [Re: OilUzer] #5210292 09/11/19 03:31 PM
M
MasterSolenoid Offline
M
I just recently checked the Vents for the Transmission and Rear Differential .
Transmission: Has a (weak) spring loaded cover. I cleaned around it / all looked good
Rear Differential: I replaced the Hose and added a Filter (just to block any dirt)
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Automatic transmission vent hose [Re: PandaBear] #5210449 09/11/19 07:01 PM
CR94 Online Content
Online Content
Originally Posted by PandaBear
It is a must. My dad's 01 Taurus had a huge amount of ATF burped on the garage floor, because the vent is too short and was stuck. ...
A must for manual transmissions and transaxles, too.
When I had a shop replace the noisy bearings in my Mazda's manual transmission, they used different oil than Mazda specified. I'm not sure the oil difference was the whole reason, but after the repair, the transmission persistently burped oil out the stubby vent pipe on top---even when low on oil. After various unsuccessful attempts to stop the spillage, I stopped it by attaching a vertical section of fuel-line hose nearly up to the hood, with a fuel filter in the middle.
2011 Toyota Prius now at 109K
