All the more reason to use a dry sump with an oil deareator in it.
Just for reference, I'm sure many do not know that the main reason a dry sump typically requires a de-aerator in the system is because of the many pumps typically required to scavenge oil back to the tank.
Correct, the dry sump pumps pull all the oil from the sump and continue to move anything that comes in contact with the pump gears. Thus the oil arrives at the tank aereated. After arrival, the hot oil flows into a funnel where gases separate from the oil. These gasses are vented to the air intake without a PCV valve (to get clogged up.)
