WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
Removing transferred dye?
by aquariuscsm - 02/17/20 08:53 AM
ST 0W-20 2013 Sienna 100k
by Mangos86 - 02/17/20 08:43 AM
Starter/Generator bearing grease
by puma4440 - 02/17/20 08:04 AM
I Did Buy the 4Runner 3.4 V6 w/253,000 miles
by Speak2Mountain - 02/17/20 07:59 AM
Proper Brake Bleeding Sequence
by Gebo - 02/17/20 07:32 AM
Do new Jeeps have death wobble?
by supton - 02/17/20 07:21 AM
New to me 2014 Passat TDi- T6?
by racin4ds - 02/17/20 07:07 AM
Chemtech Fuel Additive
by momo - 02/17/20 06:36 AM
Hydraulic oil filter cross reference
by shibby6600 - 02/17/20 01:13 AM
War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
JimMorrison, bjfangjd, 45ander5, FlightRT, 74Widebody
70724 Registered Users
109 registered members (allepunta, 2013ecof150, 1978elcamino, alchargo, AandPDan, 14 invisible), 2,405 guests, and 18 spiders.
Topics301,560
Posts5,198,107
Members70,724
Page 2 of 3 1 2 3
Re: Chainsaw Tooth Velocity [Re: MolaKule] #4707864 03/26/18 07:13 PM
cpayne5 Offline
(2*pi*1.5)x(4300/60)
first part is circumference
second is revolutions per second
full revolutions x circumference = inches traveled per second
divide by 12 to get feet
Re: Chainsaw Tooth Velocity [Re: jhellwig] #4707868 03/26/18 07:15 PM
L
Linctex Offline
L
Originally Posted By: jhellwig
Edit 3 I didn't do it right at all. 3377 ft per second.
3,300 feet per second is way faster than the speed of sound
that's high velocity rifle bullet speed
Re: Chainsaw Tooth Velocity [Re: A_Harman] #4707871 03/26/18 07:16 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Originally Posted By: A_Harman
What's the trick here? Are you going to nitpick about how tall the teeth are, which would change the tangential velocity.
How long is the bar? What is the radius of the drive sprocket?
Am I biting on your hook?
No trick just simple calcs and units conversions to get to: How far will anyone tooth travel in one second?
Sprocket radius was given as R = 1.5" and I stated that the tooth velocity (for all practical purposes) is approximately equal to the tangential velocity of the sprocket.
Bar length is immaterial.
The linear velocity of the chain, which carries the teeth and links, is the key.
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
Re: Chainsaw Tooth Velocity [Re: MolaKule] #4707879 03/26/18 07:24 PM
MolaKule Offline OP
Global Moderator
Global Moderator
A_Harmon and JimPghPA showed the correct calculations so we're going to give each a set of virtual BITOG Piston Cup Cufflinks. thumbsup
Mr cpayne5 will receive a virtual BITOG coffee stirrer. thumbsup
Re: Chainsaw Tooth Velocity [Re: MolaKule] #4707919 03/26/18 08:06 PM
Donald Offline
The teeth will travel far enough in one second to rip your skin apart big time.
2015 Ford F-250 w/Powerstroke
Re: Chainsaw Tooth Velocity [Re: Linctex] #4707937 03/26/18 08:26 PM
J
jhellwig Offline
J
Eh. I forgot to devide by 60. The first time for some dumb reason I calculated 1.5 like it was a quarter of the circumference.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Chainsaw Tooth Velocity [Re: MolaKule] #4707958 03/26/18 08:53 PM
CR94 Offline
Why such an easy question? A more accurate answer would require knowing the chain pitch (per link) and the number of teeth on the sprocket. Or you'd have to define sprocket effective radius in a particular way.
2011 Toyota Prius now at 109K
Re: Chainsaw Tooth Velocity [Re: Donald] #4708242 03/27/18 07:29 AM
MolaKule Offline OP
Global Moderator
Global Moderator
This sprocket speed was my old Homelight Chainsaw's speed.
Some chainsaws have a rotational sprocket velocity of 7000 rpm.
Re: Chainsaw Tooth Velocity [Re: CR94] #4708251 03/27/18 07:34 AM
MolaKule Offline OP
Global Moderator
Global Moderator
Apparently it wasn't that easy for everyone.
Not sure I understand your comment.
The sprocket rotates such that its Tangential Velocity is the equal to the chain's linear velocity, which is the same velocity for any tooth or link in the chain no matter where on the bar that tooth or link might be.
Re: Chainsaw Tooth Velocity [Re: JimPghPA] #4708253 03/27/18 07:37 AM
MolaKule Offline OP
Global Moderator
Global Moderator
Originally Posted By: JimPghPA
4300 RPM/60 seconds per minute = 71.66 revolutions per second.
The circumference of a circle = pi X Diameter or pi X 2 X Radius
Circumference of a 3 inch diameter circle is 3 X 3.14 = 9.42 inches
71.66 revolutions X 9.42 inches circumference = 675.0372 inches per second.
Divide by 12 to get feet per second.
675.0372/12 = 56.2531 feet per second
and
Originally Posted By: JimPghPa
4300 rev/min x 2*pi radians/rev x 1 min/60 sec x 1.5 in x 1 ft/12 in = 56.28 ft/sec, or about 38 mph.
Quite a few responders had done the calculations properly but for some reason I could not get a simple answer to:
How many feet will any one tooth travel in 1 second?
If the chain's linear velocity is 56.25 ft/sec then the distance a tooth will travel in one second is;
56.25 ft/sec X 1 sec = 56.25 feet.
Re: Chainsaw Tooth Velocity [Re: MolaKule] #4708276 03/27/18 08:10 AM
MolaKule Offline OP
Global Moderator
Global Moderator
Another way of approaching the problem is:
Data: Sprocket RPM is 4300, Sprocket Radius is 1.5".
Anything touching the outer portion of the sprocket will by necessity have to attain a velocity equal to the Tangential Velocity of the sprocket.
The chain effectively "translates" the rotational motion to Linear Motion.
Vt = w*R, where Omega w is in radians/sec, R is in inches.
There are 9.55 RPM/Radian. (One radian is 57.3 degrees of rotation of a full circle, or 0.1592 of a circle).
1/0.1592 = 6.28; 6.28 is 2*Pi.
w = 4300 RPM / (9.55 RPM/Radian) = 450.3 Radians/sec.
Vt = w*R = (450.3 Radians/sec) * 1.5" = 675.5 Inches/Sec.
(675.5 Inches/sec) / 12 inches per foot = 56.28 Feet/Sec.
56.28 Feet/sec. X 1 sec. = 56.28 feet.
Re: Chainsaw Tooth Velocity [Re: MolaKule] #5208441 09/09/19 10:50 AM
J
jakewells Offline
J
How many pins are on the rim? That would determine the speed of the chain instead of just noting the size of the rim it comes in either 6, 7, 8, 9, 10, pin.
Also i prefer using a non tacky oil in any chainsaw.
2001 Mercury Cougar base 2.5l CD4E automatic.
Re: Chainsaw Tooth Velocity [Re: jakewells] #5208689 09/09/19 05:42 PM
MolaKule Offline OP
Global Moderator
Global Moderator
It doesn't matter, as the linear velocity of the chain is a function of the Tangential Velocity of the sprocket. Put a red paint dot on any one tooth and find out how far it will travel in one second. If any one tooth is moving at a linear velocity of 56.28 Feet/sec. then in 1 second it will travel. = 56.28 feet.
Quote
Re: Chainsaw Tooth Velocity [Re: MolaKule] #5208845 09/09/19 09:27 PM
CR94 Offline
Originally Posted by MolaKule
[quote=jakewells]How many pins are on the rim? That would determine the speed of the chain instead of just noting the size of the rim it comes in either 6, 7, 8, 9, 10, pin.
It doesn't matter, as the linear velocity of the chain is a function of the Tangential Velocity of the sprocket. ...
Quote
It does matter, because the most relevant tangential velocity (that equals the chain speed) is that at the effective pitch radius of the sprocket, not at its overall outer radius.
Small difference, perhaps, but significant.
Re: Chainsaw Tooth Velocity [Re: MolaKule] #5209419 09/10/19 03:54 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I think the difference is going to be very small:
For a sprocket (from the rim toward the center of the bore) you have an Outside (or Outer) Diameter, a Pitch Diameter, and a Bottom Diameter.
See Page 3 of:
Martin Sprocket Engineering
You made me open up my old HomeLite Timberman ChainSaw but hey, it needed cleaning anyway. I put the sprocket measurements and calculations into MatLab and here are the Results:
Here are the measurements of the ChainSaw drive sprocket:
OD = 1.25"
BD = 0.75"
PD = 1.125"
Sprocket RPM = 9000
Linear Velocity using
OD = 1.25"
Sprocket RPM = 9000
49.1 ft./sec = 49.1 feet linear travel in 1 second;
PD = 1.125"
Sprocket RPM = 9000
44.2 ft./ sec. = 44.2 feet linear travel in 1 sec.
A difference of 10%.
You still need those safety Chaps and HD Gloves! cool
BTW, I need to sharpen the chain on this puppy as well. fence
Page 2 of 3 1 2 3
