What I think doesn't matter - what a UOA's results indicate, does. Without a UOA it is all guesswork, even your PCM because it doesn't actually analyze the oil- its indication is only a mathematical estimate using a complicated algorithm. As shown numerous times on this forum, no algorithm can be as accurate as a UOA.
Use what you want. Traveller will likely work very well; I simply suggested Schaeffer's because you said the redline was very expensive, so I was giving you redline performance (or better) at a lower price point.
My apologies for getting off topic and not answering… Traveller's oil will probably do just as good of job at a short interval as any other oil.
