Originally Posted by 330indy
Use Redline, and if you heat up the oil on extended drives (like an hour or more), it will last ...
and the ester polarity helps it stick to the metal even after drain down.
Dry starts are not an issue even for a rarely driven garage queen. You can go years with it, w/low mileage
So when a race team pulls the plugs and lubes the cylinder prior to starting an engine that has sat, they must not have spoken to you about dry starts not being a "thing"???
Or how about when Mobil describes (on it's website) one of the benefits of using their oil filters is minimizing "dry starts", I guess they also must not have consulted with you in re "dry starts"???🤔
Engines that are run routinely will keep a good film of oil on their internal components between uses. This film allows the engine to spin over and start, before oil pressure is established and mitigating engine damage. However, engines that sit between uses like classic cars and specialized equipment, this film of oil can dry out as oil drains from the engine and leave the engine unprotected (insufficient film) Over time repeated dry starting can cause significant engine damage.
