Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
62 registered members (928, 74Widebody, 4WD, AC1DD, 55hambone, ajchien, 5 invisible), 1,316 guests, and 19 spiders.
Topics301,810
Posts5,203,151
Members70,784
mevotech control arms? anybody with experience? #5208802 09/09/19 08:21 PM
J
jdawg13 Offline OP
J
i recently got myself a used up somewhat rusty 2005 subaru forester for cheap as a project car to use as a recreational vehicle/beater.
so, i don't mind going cheap on some parts. i am a young technician at a dealership too so i have access to the shop to work on it myself.
my question is, how do mevotech control arms hold up?
im not concerned about the bushings and ball joints, but the actual control arm itself.
i dont mind using a press and replacing the parts on it, but is the actual metal and welding decent quality?
$60/side vs $300+/side oem
huh
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5208820 09/09/19 08:45 PM
Propflux01 Offline
China quality. The brand name is just that..a name. That part prolly has 20 other 'brand' names to go with it. They will work, but don't expect OEM quality, or longevity.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5208823 09/09/19 08:50 PM
R
Rand Offline
R
on a 2005 I'd go for it.. no need to drop that much money(oem) in a 15 year old car.
Re: mevotech control arms? anybody with experience? [Re: Rand] #5208833 09/09/19 09:00 PM
J
jdawg13 Offline OP
J
Rand,
Do you have any past experience with mevotech control arms? My only concern is other parts compatibility, like if i can replace the bushings and stuff with other brand stuff. the "skeleton" of the control arm is pretty much what I am really concerned about
huh
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5208880 09/09/19 11:12 PM
The Critic Offline
It depends how long you plan to keep the car for. On the few occasions that we have installed Mevotech control arms, the bushings had become completely dry-rotted and split within 30K miles.
If Subaru sells bushings for your application, I would seriously consider that option.
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5208886 09/09/19 11:38 PM
ctechbob Online Content
Online Content
First hand experience with them in my 2008 TL. In the case of the Honda parts, the compliance bushing was WAY too soft and I replaced them with OEM parts. After that, no more problems. The metal has been fine and the smaller bushings seem to be ok. The OEM parts pressed right in, so the machining was good to go on that area.
I have MOOG arms on my Accord and those have been just fine. Their bushings were stiffer from the go.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: mevotech control arms? anybody with experience? [Re: The Critic] #5208951 09/10/19 05:00 AM
N
nobb Offline
N
This mirrors my experience with their end links. The blue rubber was no good after 2 years. Control arms are such a PITA to replace, I would use a better quality product and hopefully never have to touch it again.
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5208966 09/10/19 05:40 AM
J
Jimzz Offline
J
Metal itself is fine. The joints/bushings may be an issue on their cheaper line. But the ones you are looking at are their Supreme line. So those seem a little better than their cheaper ones.
So I don't see an issue using them in this case.
yup
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5208967 09/10/19 05:41 AM
T
Trav Offline
T
My first hand experience with them is not good, I did a pair for someone a few years ago and the car was badly out of alignment it was scrubbing the tire and could not be aligned, one arm was slightly twisted.
Back then Moog arms were okay (not the R line) but today I would much rather put a couple of good used ones on with new bushings.
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5209044 09/10/19 07:47 AM
R
Railrust Offline
R
I've used them, if you're not concerned with the bushings or ball joints, you shouldn't have a problem...the metal should hold up fine.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: mevotech control arms? anybody with experience? [Re: Trav] #5209048 09/10/19 07:55 AM
W
WyrTwister Offline
W
That is what I was wondering . Why the OP does not put new parts in the original control arm ? Maybe rust has done it in ? Do not know , Thank God I do not live in the rust / salt belt .
Wyr
God bless
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5209203 09/10/19 11:21 AM
E
eljefino Offline
E
I had one on a saturn, it was twitchy. The steering was non-linear. I could turn right, then pass a certain load point, and it would start turning further right. I think the bushing was squishing inappropriately. Still checked out good with a pry bar. Replaced it, problem went away.
That said I've run plenty of other ebay grade front end/ brake parts on beaters and been happy.
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5209236 09/10/19 12:20 PM
J
JTK Offline
J
It various so much car to car in terms of where aftermarket parts come from and the quality they are. It's a tough call. If you were flipping the car or only wanted a year or two out of it, go cheap. If you can wait on mail order parts and do the work yourself, mail-order all the way.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: mevotech control arms? anybody with experience? [Re: WyrTwister] #5209537 09/10/19 06:35 PM
T
Trav Offline
T
Plenty of good used ones that vintage up here, may are OE replacements done not long ago along with CV axles, springs and struts. Throw a couple of bushings and a joint in and its good to go.
Re: mevotech control arms? anybody with experience? [Re: jdawg13] #5209706 09/10/19 10:19 PM
J
jdawg13 Offline OP
J
thanks guys, i think im gonna go with it.
if i were to get the arms and replace literally all the bushings and ball joints on it from the get go, it would still cut the costs a bit over 2x of buying all oem.
but i dont find removing and installing control arms to be hard at all so ill see how long the original mevotech bushings and stuff last!
and yeah the original arms on it right now are a bit rusty, these models had an issue of the hangers breaking when rusted enough. the last thing i want when im out camping in the woods or desert is for them to break
huh
