Had a P2A00 code and replaced Bank 1 Sensor 1 O2. Code gone now. With scantool reading voltages on new sensor (B1S1) reading around .29-.3 volts and B2S1 reading around .59-.60 Volts. When lean in decel volts just to .85ish on B1S1 and 1.27 on old sensor B2
Should I also replace B2S1 so both side are more closely aligned in their readings?
TKS in advance.
TKS in advance.
