Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
85 registered members (Aichiguy, 2010Civic, AZjeff, 55hambone, 4WD, 2strokeNorthstar, 7 invisible), 1,481 guests, and 17 spiders.
Topics301,809
Posts5,203,132
Members70,784
Page 2 of 3 1 2 3
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208192 09/09/19 03:47 AM
demarpaint Offline
This works. Hard to see oil level check. It's a variation of what I've been doing since shop class in the 70's, and the blue paper towel method. I found ATF can be a PITA to check after a transmission service and fluid exchange.
God Bless Our Troops
Re: Difficulty reading dipstick to accurately check oil level? [Re: slacktide_bitog] #5208219 09/09/19 05:14 AM
J
joekingcorvette Offline
J
Originally Posted by slacktide_bitog
Honda uses an orange plastic dipstick on their newer cars, and it is impossible to see the oil until it darkens during the OCI mad
I was going to say the same thing. It's very difficult on my 2012 Civic and my old 2006 Civic to read the orange dipstick.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208237 09/09/19 05:51 AM
F
Fawteen Offline
F
I just use a paper towel. Pull the dipstick and lay the end on the white paper towel and you'll see exactly where the oil level is.
Re: Difficulty reading dipstick to accurately check oil level? [Re: slacktide_bitog] #5208281 09/09/19 07:14 AM
Z
zzyzzx Offline
Z
Is an aftermarket metal one available?
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208307 09/09/19 07:50 AM
K
KrisZ Offline
K
A good case to use Royal Purple? LOL
My Mazda 3 is the same. Very hard to read with fresh oil, but I've learned to live with it and look at various angles to see the light reflect from the wet oil.
Plus I know it takes 4 liters to get it to the full mark.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208329 09/09/19 08:24 AM
J
JeffKeryk Offline
J
Paper towel works.
I just slowly run my finger down the dipstick until I strike oil.
Then I add more until it's overfilled. Sheesh.
Fast, easy and simple.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208345 09/09/19 08:42 AM
J
Jimkobb Offline
J
On my 14 Corolla that uses no oil when I check the stick it doesn`t seem to stick evenly to the stick. I think at the low end of the stick instead of being so smooth they should be a kind of rough surface .
green_bay_packers_logo_small[1]
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208355 09/09/19 08:58 AM
L
Lubener Offline
L
If you allowed it to drain completely, put what is suggested in the manual. Check the oil the next morning before starting. If the level does not show full, use a scribe to mark where the level is at on the dip stick. I had to do that on my Fords.
The "thinking" man's friend.
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208408 09/09/19 10:15 AM
R
ragtoplvr Offline
R
It is really fun to check clean new transmission fluid when it is hot to get the correct level. I will take motor oil that can be checked cold any day.
Rod
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208456 09/09/19 11:06 AM
DGXR Offline
Yes this is a common issue. The most effective way is to pull the dipstick and leave it out for at least 30 minutes. Wipe it off REALLY good, push it in and pull it out, then hold it near a light and you should see the shiny area pretty easily. I like the idea of laying it down on a paper towel to see where it gets wet, but you need to be careful not to move the stick around too much or it will get confusing where the oil level is.
I know you are meticulous about maintaining a FULL reading but really, if you're not pushing the truck hard, it only needs to read between the ADD and FULL marks -- this is called the "safe zone" by most manufacturers, for a reason.
If you are towing, hauling, crawling/wheeling, or other severe service, then it would be best to maintain the level at or near the FULL mark.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208578 09/09/19 02:45 PM
E
Ed_Flecko Offline OP
E
Thank you all for your input, feedback and suggestions.
smile
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208591 09/09/19 03:09 PM
K
kstanf150 Online Content
Online Content
K
Dipstick on my Fords are a darkish grey color so I take some sandpaper or sanding foam block and sand of the finish to a shiny surface
Problem solved
Easy to see then, clean or dirty oil
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208981 09/10/19 06:25 AM
A
AurionX2 Offline
A
PITA to read the oil level on 2gr-fe. I can only recommend what other posters before suggested: read the dipstick when cold, before cranking the engine in the morning without reinserting it to read it again, cause the second reading will look vastly different :-) :-) Or in the afternoon when leaving the office before heading home will also work, 8-8:30 hours is enough to get an accurate reading.
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5209074 09/10/19 08:27 AM
J
Jimkobb Offline
J
Yep AurionX2, I agree with checking it first thing in the morning before a drive. I found that it shows up better on the dipstick for me.
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5209089 09/10/19 08:37 AM
Quattro Pete Offline
My Charger is horrible when it comes to reading the oil dipstick. I just cannot tell the level AT ALL, no matter what I do. The oil is smeared all over the dipstick.
If you can't figure out how to design a legible dipstick, you should at least display the level electronically in the dashboard, but of course FCA didn't bother with that either. It's the little things like that which differentiate good cars from great cars.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Page 2 of 3 1 2 3
