Pride Asian Plus Coolant-thoughts?
by N Heat - 11/19/19 04:21 PM
Should it really take this long?
by IronMaidenRules - 11/19/19 02:21 PM
Does Ford use Hall Effect sensor for the APPS?
by LoneRanger - 11/19/19 02:09 PM
Brake Calipers for my 74 Corvette
by Alwyn678 - 11/19/19 01:32 PM
My Neighbor's 320,000 Mile Saturn
by CrackyWainwright - 11/19/19 01:14 PM
2012 GMC Terrain 3.0L V6 P0300
by benjamming - 11/19/19 12:51 PM
Mustang 4r70w atf recommendation
by Hansvoytek - 11/19/19 12:18 PM
PRO TEC PTL 57502 CUT OPEN
by 53' Stude - 11/19/19 12:08 PM
Federal rebates?
by buck91 - 11/19/19 12:07 PM
Bosch fuel pump quality
by drtyler - 11/19/19 11:28 AM
Standard Motor Products
by Whimsey - 11/19/19 11:25 AM
Delo SynBlend 15w40 - $11.45
by Greg L - 11/19/19 11:17 AM
VIRGIN STP 8316 CUT OPEN
by 53' Stude - 11/19/19 11:00 AM
FPPF: Polar Power & Total Power
by BigJohn - 11/19/19 10:40 AM
Quality filter for 2017 Subaru 2.5 Ltr
by Ishmael - 11/19/19 10:39 AM
Kendall GT-1 Max vs PP
by c5z06 - 11/19/19 10:25 AM
Toyota Sienna FWD in Snow / Ice
by tiredguy - 11/19/19 09:32 AM
7.62 x 39 Top Three?
by CCI - 11/19/19 09:30 AM
MOTUL Specific VW 508.00 Unboxing
by ARCOgraphite - 11/19/19 09:14 AM
A few Ford part number filters cut open
by mpgo4th - 11/19/19 09:08 AM
dshadow, Hansvoytek, DeltaP71, 300Kncounting, Bill67
69917 Registered Users
99 registered members (2002 Maxima SE, 92saturnsl2, 53' Stude, Al, Aichiguy, 1978elcamino, 8 invisible), 2,026 guests, and 21 spiders.
Topics297,641
Posts5,119,868
Members69,917
Most Online3,589
Nov 2nd, 2019
Page 2 of 3 1 2 3
Re: Champion XC12YC plugs..anything better? [Re: Mamala Bay] #5208186 09/09/19 03:27 AM
L
Lubener Offline
L
Originally Posted by Mamala Bay
Originally Posted by bchannell
I don't see that it matters what you use, as long as it's the equivalent plug to what's specified. Lots of folks say, use Japanese plugs in Japanese engines, American plugs in American engines etc. I blasphemed and used Autolite in my Kawasaki, and it's running just fine. Does it run better than NGK, I can't see that it does, I can't tell any difference between decent plugs. I've read where some say one brand or the other simply won't run in their engine, who knows, I can't imagine it's a big deal.
When you put many hours on a small engine that stress the spark plug on a commercial level you will notice the difference . Again any spark plug will work fine for home usage with LITTLE hour usage that doesn't have stress on the spark plug vs commercial.
That said Champion is crap vs NGK on a commercial level from my experience not the same league . I don't trust CHAMPION plugs. With many hours of usage stress on a spark plug I'll take the NGK from my experience.
I have used Champions in farm use environments and that exceeds any stress that is encountered in commercial use. I never had any problems with them. I have had issues with NGK for home use and will not use them.
The "thinking" man's friend.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5208215 09/09/19 05:11 AM
1
123Saab Offline
1
NGK or Bosch has never given me any trouble at all. From chainsaws to chippers to 300hp+ tuned 4cyl's.
I see no reason to use anything else, personally.
Anything can happen
The tallest towers be overturned
Those in high places be daunted
Those overlooked regarded
- Seamus Heaney
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5208241 09/09/19 06:02 AM
J
jeepman3071 Offline
J
I've never had an issue with Champions, and I've also never noticed a difference between plug brands besides the Chinese "Torch" brand which come on the clone engines and are terrible. I believe NGK to be the best quality, but a lawn mower will run just fine on Champions, and it won't run any better on something more expensive. Just use the manufacturer recommended plug and change it at the interval they suggest.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (52k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5208361 09/09/19 09:08 AM
R
RichardZ Offline OP
R
Thanks for all the responses! The mower does run fine. I guess I'll stick with the Champions..
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5208792 09/09/19 08:10 PM
M
Mamala Bay Offline
M
You're choice, NGK last longer more durable and better starting than Champion. NGK is a better built plug. A good test was a defective Kohler small engine splash lube system which ran much hotter than normal. The Champion plugs wouldn't last hard starting just kept fouling out. In NGK took the heat and beatings and kept on ticking...get the picture.
We gave the Champion a fair test but after 5 Champion plugs that failed in a short time and the first NGK that kept ticking I'l take the NGK.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5208958 09/10/19 05:16 AM
dave123 Offline
It might as well be a Ford vs Chevy debate
Re: Champion XC12YC plugs..anything better? [Re: dave123] #5208991 09/10/19 06:43 AM
1
123Saab Offline
1
Not at all.
Pays to stay informed, this is not a brand popularity contest.
Anything can happen
- Seamus Heaney
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5209036 09/10/19 07:31 AM
R
ragtoplvr Online Content
Online Content
R
I had a Dixon mower go to its grave, deck was rotten not worth rebuilding the transmission, . It still had the original champion plug, it had never been removed. Started and ran fine. Probably had over 1000 hours on it, was 30 years old.
My tiller was so worn out I do not know how it ran, you could only till about 10 to 15 minutes before the 20W50 got hot and thin and the smoking got bad. Original champion plug, it had to be removed and cleaned once and a while.
79 model lawnboy, still the discontinued CJ14 plug it came out with. I have not touched it in about 5 years now. Still runs fine. Starts second pull same as always.
My generator has served thru 5 10 day power outages, still the original torch plug.
I wonder how you guys have so much trouble.
Rod
Re: Champion XC12YC plugs..anything better? [Re: ragtoplvr] #5209210 09/10/19 11:29 AM
1
123Saab Offline
1
Rod
Good for you.
On a sidenote, no one has ever backed in to my mailbox. It's because its cheap plastic I'm sure.
Anything can happen
- Seamus Heaney
Re: Champion XC12YC plugs..anything better? [Re: Mamala Bay] #5209264 09/10/19 01:02 PM
B
bchannell Offline
B
I dunno, I've gone through six tractors, three JD, one WH, one Husq, one Simplicity, and owned a few others at the same time, that the previous tractors were my main mower. I mow about 6 acres a week, and do plenty of tree trimming, and log hauling work. I know it's not commercial use, but it's a fair amount of hard work. I have over 700 hrs on my present JD 425, and I've used NGK, Champion, and now Autolite. I can't say any of them were better than the others. I can say the Champions looked like they were made by grade schoolers in shop class, the quality control was just awful, but they did run ok with no hiccups. I don't use them anymore simply because other plugs are just as easily obtained, and seem much better made.I stress my equipment pretty hard, up hills and over banks hauling everything under the sun, cutting grass that got way to high because of rain or work or whatever. None of the plugs actually wore out, but I just replace them every so often to keep it fresh. From looking at the Champions quality, it doesn't surprise me that you say they don't last in commercial use, but for me and a lot of others that just simply isn't the case. My Husq never had anything but a Champion plug in it from new and is still running on Champions, maybe the same ones, who knows to this day, as a church has it now, and I doubt they do any maintaince on it, and it's a 2010 model, not too shabby.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5211255 09/12/19 08:40 PM
T
tundraotto Online Content
Online Content
T
NGK.....about a 100 plugs changed....
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5211265 09/12/19 09:05 PM
spasm3 Offline
Autolite XP3924 XP iridium.
Should be a cross ref to the xc12yc.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 16400 miles m1 0w40
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5211435 09/13/19 05:50 AM
J
jeepman3071 Offline
J
All this for a mower with not even enough hours to warrant a plug change. duh I doubt you will notice any difference between a Champion, NGK, Autolite, etc in a normally running mower engine.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5212852 09/14/19 10:29 PM
B
bubbatime Offline
B
This is obviously a very opinionated topic. I used to be the NGK or nothing guy above. Until I ran a small engine shop. Maintaining commercial mowers. Thousands of hours on factory Champion plugs, engines ran fine. I’m a big fan of Made in USA champion plugs after actually using them on hundreds/thousands of engines and seeing how long they last, working perfect.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5213390 09/15/19 12:50 PM
B
bchannell Offline
B
I just walked into the house after talking to my neighbor, who was telling me you can't use dino oil and then switch to syn, then go back to dino (YES, he used to be an Auto Zone employee!!!!!)?? I didn't bother telling him, I have two tractors, three cars, and have had many more of both, that were run many thousands of miles/hours using which ever I thought was good at the time. Spark plugs seem to be the same cup of tea, so much hype, advertising, and mis information, like oil, that doesn't hold water when it comes to actual use. I love reading the posts about someone using brand X oil, and how it made the car run so much smoother, start better, more power, etc, when we all know, the chances you could actually tell any difference from running Redline or Rural King! Did you ever watch or read those studies where people were asked to pick the best tasting bottled water, in a blind test, and they invariably choose bottled tap water?
Hey, I'm not making fun of anyone, as I used to bite on the same stuff some of the time, it's so pervasive, it's hard to understand real statistics and real anecdotal "statistics".
Page 2 of 3 1 2 3
