1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
70 registered members (AJB0009, 14Accent, amh, aba4430, Alfred_B, AndyB, 7 invisible), 1,712 guests, and 74 spiders.
Topics306,083
Posts5,287,071
Members71,596
Page 1 of 3 1 2 3
Champion XC12YC plugs..anything better? #5207119 09/07/19 02:59 PM
R
RichardZ Offline OP
R
My Husqvarna riding mower calls for Champion XC12YC sparkplugs. I’m approaching 100 hrs on it. I the Champion XC12YC a decent plug or is there a better option? Just wondering…
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207130 09/07/19 03:16 PM
R
RyanY Offline
R
I am by no means an expert, but I usually go with the manufacturer recommended brand/model unless I have a reason not to (i.e., to solve a problem). For example, my Hitachi equip uses Champion, Honda uses NGK, etc and i have never had any problems with this approach.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207131 09/07/19 03:17 PM
M
mk378 Online Content
Online Content
M
If I were replacing them I'd use the NGK equivalent. But 100 hours is way too early to consider replacement.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207142 09/07/19 03:34 PM
slacktide_bitog Offline
NGK BKR5E smile
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207162 09/07/19 03:57 PM
FA_WRX Offline
My suggestion would akso be NGK over champion.
2015 WRX FA20F
Shell RGT 5W30
WIX 10078
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207174 09/07/19 04:08 PM
old1 Offline
I have used Champion plugs in virtually everything for the past 50 years without any problems. Only time I used other brands was if the customer requested it.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207197 09/07/19 04:52 PM
147_Grain Offline
NGK
2019 Subaru Crosstreck
2013 Subaru Outback 3.6
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207203 09/07/19 04:58 PM
E
Eddie Offline
E
MY 20 HP B&S twin came with Champions and I replace them with same. Never a problem so I see no reason to change. Most engines for lawn equipment suggest 50 to 100 hours for spark plug change. Ed
2014 CX5 Touring 2.5L :-)
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207230 09/07/19 05:35 PM
B
BigD1 Offline
B
Bought that same Champion plug at O'reillys for about $2 back in the Spring of this year. Made in USA, and it's been doing just fine.
1992 Toyota Pickup--SuperTech 10W-30 conventional--Fram PH3614
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207350 09/07/19 08:55 PM
J
jakewells Offline
J
I use NGK in all my small engines i change my plugs every 250 hours.
2001 Mercury Cougar base 2.5l CD4E automatic.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207422 09/07/19 11:35 PM
M
Mainia Offline
M
NGK is the Lexus of spark plugs. Champion the Pontiac of sparkplugs. They both work.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207469 09/08/19 03:51 AM
O
Olas Offline
O
Thread, gap, reach and heat range are the only important things to consider. An air gap is an air gap no matter which company produced it - X voltage is required to jump Y gap.
Brand means nothing.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207484 09/08/19 05:18 AM
L
Lubener Offline
L
Did it perform ok for you??? I never fool with success and I have always used Champions in all my small engines and never had any problems with them. If the plug looks ok, regap and reinstall them. I have plugs with close to 300 hours on them and they still look and perform well.
The "thinking" man's friend.
Re: Champion XC12YC plugs..anything better? [Re: RichardZ] #5207686 09/08/19 12:51 PM
B
bchannell Offline
B
I don't see that it matters what you use, as long as it's the equivalent plug to what's specified. Lots of folks say, use Japanese plugs in Japanese engines, American plugs in American engines etc. I blasphemed and used Autolite in my Kawasaki, and it's running just fine. Does it run better than NGK, I can't see that it does, I can't tell any difference between decent plugs. I've read where some say one brand or the other simply won't run in their engine, who knows, I can't imagine it's a big deal.
Re: Champion XC12YC plugs..anything better? [Re: bchannell] #5208126 09/09/19 12:14 AM
M
Mamala Bay Offline
M
When you put many hours on a small engine that stress the spark plug on a commercial level you will notice the difference . Again any spark plug will work fine for home usage with LITTLE hour usage that doesn't have stress on the spark plug vs commercial.
That said Champion is crap vs NGK on a commercial level from my experience not the same league . I don't trust CHAMPION plugs. With many hours of usage stress on a spark plug I'll take the NGK from my experience.
Page 1 of 3 1 2 3
