New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
29 registered members (bbhero, Black_Thunder, Bighorn2500, d00df00d, Char Baby, ctechbob, 3 invisible), 1,566 guests, and 20 spiders.
Topics300,519
Posts5,177,614
Members70,518
Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L #5206783 09/07/19 03:29 AM
R
Robster Offline OP
R
This sample was taken at the last oil change, which was the 2nd one for this vehicle since new. As noted in the report, there's still some wear-in metals, silicon etc. showing up due to the low total mileage, which I expected. This analysis was more about oil performance than the wear metals at this point. The moly content was higher than I anticipated--since this was the 2nd oil change on this vehicle, I would have expected the assembly lube to have been removed with the factory fill (1st oil change), so I'm a little puzzled by that amount. The viscosity was well within normal limits and the TBN was still good. Insolubles look good (Fram XG9688 filter). I'll likely use this combination going forward.
2017 RAM 1500 Big Horn 5.7L:Valvoline AFS 5w-20, Fram TG10060
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-20 / OEM filter
2013 Victory Cross Country:Valvoline 4T syn 10w-40, NAPA Gold
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5206800 09/07/19 04:37 AM
G
Gubkin Offline
G
TBN 2.1 is critical
oil is dead
use 5-40 MB 229.5 full saps
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5206810 09/07/19 04:48 AM
M
MParr Offline
M
You may want something that starts off a little thicker than the Valvoline. Here are 3 good choices; Mobil 1 original, QSUD and Havoline Pro DS.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
93 Octane Non-Ethanol
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Gubkin] #5206846 09/07/19 05:46 AM
J
jbutch Offline
J
Originally Posted by Gubkin
TBN 2.1 is critical
oil is dead
From what I read, TBN depletion is not linear.
Excellent wear metals, I'd go for 5k oci with that combo.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: jbutch] #5206873 09/07/19 06:45 AM
M
Mad_Hatter Offline
M
TBN 2.1 is critical
oil is dead
It's not linear...
While the BN still has life, you may have ran the oil too long as far as viscosity goes. The standard range for a SAE 30 is 9.3~13.5..and your FP looks low. (due to slight FD?).. Maybe this is all due to the engine still breaking in (rings, valve seals???)
I've seen some great UOA's by Valvoline Advanced, so maybe this UOA is an outlier on an engine still breaking in. Run it again and see what turns up.
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Mad_Hatter] #5206884 09/07/19 07:10 AM
R
Robster Offline OP
R
TBN 2.1 is critical
oil is dead
It's not linear...
I put the same combo back in at this oil change. The 2.1 TBN doesn't concern me--I doubt I'd ever exceed 5000 miles on an OCI in this vehicle. As for the viscosity, it seems like it falls comfortably within the spread listed by Blackstone for a 5/30. As for fuel dilution, I've seen worse from other DI engines. I'll likely do another UOA after a few more oil changes. NOTE: Hyundai suggests a 5w/20 for this engine, but 5w/30 is also approved for use.
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5206892 09/07/19 07:23 AM
A
ARCOgraphite Offline
A
Looks good, but Surprised TBN is at 2 in under 5k miles.
Lot of short trips?
How many months was the oil in service?
Thanks for the report. I just posted UOA on this oil also.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5206896 09/07/19 07:30 AM
M
Mad_Hatter Offline
M
TBN 2.1 is critical
oil is dead
It's not linear...
Yeah, it's not a bad report. There's just a couple of things that stood out to me but I wouldn't put too much worry into them at this point since it's still breaking in and things are setting.
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: ARCOgraphite] #5206953 09/07/19 08:49 AM
R
Robster Offline OP
R
Lot of short trips?
My wife's commute is only about 8 miles (each way) of highway, with a few miles in a city environment (stop and go). She does idle the car a lot at times.
The oil was in use from 3/15/19 to 8/17/19.
I think the oil held up pretty well under the circumstances.
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5206991 09/07/19 10:10 AM
csandste Offline
My girl friend has 2.4 in her '17 Optima Hertz rental car. Running about 6500 miles Magnatec until it gets around to an odometer reading divisible by 5000 then it'll be conventional*(syn blend really) 5w30. Same with my 2 liter Soul and my daughter's 1.6 liter Accent. Think the secret on these things is relatively short OCI's given the GDI. I think your oil looks fine, what's wrong with a TBN of 2?
* If we didn't live in condos and could change our oil it would be a low end syn.
2017 Kia Soul Plus-- VWB 5w30+ a bit of Harvest King syn 5w30-- 70,000 miles
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: csandste] #5207275 09/07/19 05:57 PM
M
Mad_Hatter Offline
M
Nothing per se, IMO. It's on the "low" end but there's still life there... the oils corrosion inhibitors are doing it's job, if the TBN is at 2 and that's concerning (not to me)... don't blame the lube, "blame" the engine because I've seen this lube stand up to drain intervals twice this long with a TBN of ~3. You have to look at this report in context, this engine is in its infancy and since this report doesn't exactly have any glaring red flags I'd give it a couple more oci's before reaching any long term conclusions either way... but that's just me.
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5207286 09/07/19 06:27 PM
ChrisD46 Offline
I'm not surprised by the TBN on VAS 5W30 for 4,600 miles ... I have the same 2.4l GDI engine in my /17 Sonata at 28K miles on it using the same oil and I won't go more than 5K mile OCI's on it .
*I wonder what VAS 5W20 would look like at 4,600 miles ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: Robster] #5207328 09/07/19 07:20 PM
J
JustinH Offline
J
I stick to the 3750 mile severe service for my 2.4L.
Dealer changes it with semi syn for $30.50 including shop fees, new crush washer, and new hyundai filter.
'16 Ford Escape
'11 Scion XB
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: JustinH] #5207403 09/07/19 09:18 PM
M
Mad_Hatter Offline
M
That's a good price for a dealer oil change.👍
Re: Valvoline 5w/30 Advanced Full Syn, '19 Hyundai Santa Fe 2.4L [Re: JustinH] #5207462 09/08/19 01:55 AM
R
Robster Offline OP
R
Same here, unless my wife's driving routine changes. I set the maintenance minder at 4000-sometimes I do it a little early, sometimes it goes a little over (like this time). It seems that with this oil I have a little safety margin if I go over, although any brand would handle this OCI with no problem.
