MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
110 registered members (AC1DD, 2013ecof150, 01VFR, Ag76, ABursell, 2003f7, 11 invisible), 1,828 guests, and 22 spiders.
Topics301,807
Posts5,203,096
Members70,784
Honda Civic 2009 LX struggles to start at random #5206757 09/07/19 12:01 AM
SpicySenpai Offline OP
I checked the battery with a multi-meter its fine, I went to walmart and they said my battery is fine.
Alternator works, once the car starts it goes above 14v.
I'm not sure if the starter is the problem because I can't reach it to tap it.
So basically what happens it that occasionally my car would struggle to start - it would crank but not continuously - like it'll have a 0.5 - 1 second delay before it starts and when it gets worse it skips a crank and it would take me 3 or more tries for it to turn-over.
I'm totally lost on what to do - I can fix parts by going to Youtube but I have no clue how to diagnose this.
Does anyone know what's wrong with my car?
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5206781 09/07/19 02:57 AM
Char Baby Offline
Hmmm!
Check the ground and also check for rodent damage...somewhere!
Also, is the Ignition Timing off/jump timing?
When it does start, how does it run?
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Honda Civic 2009 LX struggles to start at random [Re: Char Baby] #5206822 09/07/19 05:07 AM
Char Baby Offline
I am also wondering if there is a starter gear tooth missing or on the flywheel.
"Retired"
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5206938 09/07/19 08:28 AM
MrMoody Offline
When it fails, what happens exactly?
Crank over but no fire?
Grind/Zing?
Click?
Nothing?
Do the instrument panel/interior lights stay on or go dim/cut off?
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5206965 09/07/19 09:21 AM
T
t1snwrbrdr12 Offline
T
I’ve been a mechanic professionally since 2003 and longer than that as a hobby. When my starter failed on my 2003 accord 4 cylinder it acted as you describe. I hadn’t seen or experienced a starter fail like that before.
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5206969 09/07/19 09:22 AM
J
JeffKeryk Online Content
Online Content
J
My guess is the starter is starting to drag.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Honda Civic 2009 LX struggles to start at random [Re: t1snwrbrdr12] #5207097 09/07/19 01:22 PM
Originally Posted by Char Baby
Hmmm!
It runs fine, just doesn't hit the right MPG anymore. Timing wise not sure, it doesn't use a timing belt only chain.
I'd like to know as well, its just such a [censored] to change the starter.
Grind/Zing?
Click?
Nothing?
A normal working car sounds like this *Crank* *Crank* *Crank* *turn over*
My car when its failing it sounds like this:
1st try: *Crank* -------- Cra..nk? ----- uh hello?--- *small crank* lol try again pal
2nd try: *Crank* ------- *small crank* --------- NO
3rd try: *Crank* -- *Crank* -- *Turn O-- *cough* just kidding
4th try: *Crank* --- *Crank* - *Crank* ---I think we got th.. *TURN OVERRRRRRR*
This car seems like a lemon deal but we got it used. We bought this around 9000 miles from someone who was legally going blind so he couldn't drive and sold it to us for cheap and around 15,000 miles the bearing seemed to already fail, when I bought it from my parents I had to get it fixed. It just went downhill from there
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5207112 09/07/19 01:48 PM
M
mk378 Offline
M
Turn on the headlights or the dome light and watch when you try to start. Is the whole car losing power? It's real common to have bad connections at the battery make the entire electrical system die when trying to start. It would be a good idea to remove, clean, and reconnect the battery terminals in any case.
If you have good power but it doesn't turn it is probably the starter itself.
Re: Honda Civic 2009 LX struggles to start at random [Re: mk378] #5207201 09/07/19 03:56 PM
I think I do have good power but I'm curious about it - it's not losing power but it dims whenever I turn on my car. I already cleaned the terminals remove and reconnected I even cleaned it with wire brush and sandpaper.
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5207236 09/07/19 04:45 PM
M
mattd Offline
M
Have you load tested the battery? I would not trust Walmart for what it’s worth. The dim lights suggest that it’s a voltage issue
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Honda Civic 2009 LX struggles to start at random [Re: mattd] #5207254 09/07/19 05:15 PM
Where should I get it checked? Pepboys? Autozone? I checked it with my Multimeter and its fine it reads 12.60v, down to 11v during crank and then 14.6x while running.
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5207261 09/07/19 05:33 PM
M
mattd Offline
M
11 during cranking is OK. Can you post a video or sound clip of when it acts up?
ASE Master, L1, L2
Re: Honda Civic 2009 LX struggles to start at random [Re: mattd] #5207451 09/08/19 12:48 AM
Sure I'l get back to you guys when I do
Re: Honda Civic 2009 LX struggles to start at random [Re: t1snwrbrdr12] #5207455 09/08/19 01:07 AM
The Critic Offline
Agreed, I have seen this behavior multiple times on Honda K24 engines.
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Honda Civic 2009 LX struggles to start at random [Re: SpicySenpai] #5207463 09/08/19 02:03 AM
P
pitzel Offline
P
How old is the starter? Repair could be as easy as brushes....
Change your thinking...not your oil!
Turn your mind....not your rotors!
