BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
PeterNST, SkinnRS, Bama65, wjamyers, L00btech
70793 Registered Users
120 registered members (1978elcamino, alanwayne1908, AlaskaMike, alchargo, 4WD, ARB1977, 10 invisible), 2,621 guests, and 19 spiders.
Topics301,864
Posts5,204,252
Members70,793
Page 2 of 2 1 2
Re: BG MOA [Re: Grambo] #5207457 09/08/19 01:10 AM
The Critic Offline
FWIW:
Quote
March 7, 2019
WICHITA, Kan. – New BG Advanced Formula MOA® has been upgraded from BG Extended Life MOA®. The new chemistry now meets API SN Plus standards and is specially formulated to protect turbocharged gasoline direct injection engines from Low Speed Pre-Ignition (LSPI).
BG Advanced Formula MOA® also protects vehicles with downsized, boosted engines, which have hotter combustion temperatures, higher cylinder pressures, less piston ring tension and tighter tolerances than ever. This unstable environment is conducive to deposit formation and buildup.
Even high quality synthetic oils will degrade eventually. Unless the oil is fortified with enhanced protection against high heat, premature and hard-to-remove deposits will form on many engine components.
BG Advanced Formula MOA® is formulated with 100 percent synthetic chemistry. When added to engine oil, it protects engine components and fortifies all brands of engine oil for today’s extended oil drain intervals.
LSPI safe
Keeps piston rings from sticking
Reduces wear
Stabilizes oil viscosity
Prevents sludge and varnish
Prevents increased exhaust emissions
Ensures reliability of critical engine components
Prevents excessive oil consumption
Extends engine life
Meets API SN Plus standards
Backed by the Lifetime BG Protection Plan® for up to $6,000
Automotive experts nationwide chose BG MOA® 5 to 1 over the nearest aftermarket competitor.* Find a BG shop near you and ask for BG Advanced Formula MOA® at your next oil change.
https://www.bgprod.com/blog/bg-advanced-formula-moa-is-now-lspi-safe/
IMO, BG is the most legitimate of the snake oil companies.
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: BG MOA [Re: Grambo] #5207576 09/08/19 08:08 AM
RTexasF Offline
In the past all Acura dealers included BG MOA with an oil/filter change. I don't know if that is still practiced.
Re: BG MOA [Re: RTexasF] #5207647 09/08/19 10:20 AM
T
Trav Offline
T
Yet all these dealers that offer these services are going against the manufacturers recommendation that additives not be used. These are huge profit makers for the dealerships with spiffs for the mechanics in the form of tokens in the cans.
Some BG products work better than others, the only real difference I can tell in the new and improved MOA is the synthetic oil carrier instead of dino. Very high priced for what you get.
I try to use products that work to address specific issues not just tossing products in because of some advertising claims. Legit issues like sticking rings and lifters, rear main leaks on older cars that would be cost prohibitive to repair and so on deserve a Hail Mary pass before an expensive tear down but that's about it otherwise modern engine oils are doing everything needed to keep the engine in good shape if maintained regularly.
Re: BG MOA [Re: Grambo] #5207940 09/08/19 05:51 PM
R
red7404 Offline
R
i live in Wichita, KS. home of BG. the mechanics i know say nothing but good about BG.
Re: BG MOA [Re: red7404] #5207974 09/08/19 06:25 PM
T
Trav Offline
T
Sure they do wouldn't you if everything you peddled and used had a token in it you could redeem? Some of their product are not bad but all are dramatically over priced.
I wait for someone to explain why manufacturers dealerships are peddling this stuff when the company they represent specifically states in the owners manuals that additives should not be used.
It certainly doesn't say non except the sometimes multi hundred dollar BG services offered by some of our dealerships. On top of that when they do recommend something it is with products with their own branding eg Toyota, Chrysler, Subaru, GM, etc top engine cleaner, coolant, trans fluids, engine oils and engine cooling system flushes.
They will stand behind the warranty if their branded products are used and something goes afoul.
Re: BG MOA [Re: Grambo] #5208043 09/08/19 08:19 PM
M
Mad_Hatter Offline
M
I just think for $13, $16 or more for an oil additive at each change...why wouldn't I just spend that money on a higher quality finished lube? For $25 I could just run Edge EP or M1 EP for only 6k mile oci's and still come out ahead.
From the way some of these additive makers describe their product, makes me believe I could add it to a grp1 and run it 10k miles!😂
Re: BG MOA [Re: Mad_Hatter] #5208256 09/09/19 06:25 AM
T
Trav Offline
T
That is a fact and well said!
Re: BG MOA [Re: Grambo] #5215222 09/17/19 11:28 AM
N
nicholas Offline
N
I prefer to go with Lubegard Bio for engine oil.
2019 2.0T Santa Fe
2010 3.5 Santa Fe
Re: BG MOA [Re: Grambo] #5239200 10/14/19 08:53 AM
R
red7404 Offline
R
IMHO manufacturers dont approve any products. is that the manufacturers cant spend time testing EVERY products.
Re: BG MOA [Re: Grambo] #5239506 10/14/19 03:16 PM
ChrisD46 Offline
If I feel the need every few oil changes - I'll use Sea Foam (< $ 7.00 per can at WM) @ 1 oz. per qrt. of oil capacity in the engine for a run up to 300 miles before an oil change ... Other wise , like the earlier poster said - why not just run Castrol EDGE or M1 EP for a 6K OCI ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: BG MOA [Re: Grambo] #5275877 11/23/19 11:29 PM
postjeeprcr Offline
Originally Posted by Grambo
Hey Guys i was just curious who uses BG motor oil additive, Any thoughts or opinions. its going to be the first time i use it.
Thanks in advance
Grambo you should do a search for BG MOA as there are many threads on it.
If I agreed with you, we'd both be wrong.
Page 2 of 2 1 2
