Hi
we're diagnosing a pal's new used bike, 2011 Honda CBF600N motorcycle.
It ran great a couple of days (5) after buying, then started acting crazy when upshifting, like ignition cut.
Now, it would start and ran a couple seconds on all cylinders at idle, then starts running on ... 2 (sounds like that), and as soon as you start rolling, no matter what RPMs, it stalls.
Do you think it could likely be ignition coils acting up, or can a sensor (TPS etc.) may be the culprit ?
I unplugged and shorted the side stand switch connector for test purposes but it acts the same.
Thanks bitog !
Thanks bitog !
