Favorite Honda Acura filters
by JeffKeryk - 04/07/20 11:09 AM
Samsung Quitting LCD Business
by SubLGT - 04/07/20 10:59 AM
Moisture inside double pane glass doors.
by Cujet - 04/07/20 09:51 AM
When did mechanics start using rubber gloves?
by atikovi - 04/07/20 09:33 AM
Gearless ratchet
by Farnsworth - 04/07/20 09:22 AM
Troy bilt Zero turn hydrostat fluid?
by racin4ds - 04/07/20 09:20 AM
Bad experience with Monroe strut assembly
by sasilverbullet - 04/07/20 09:16 AM
Hitachi CG22EASSLP
by passgas55 - 04/07/20 09:03 AM
Update: Oil turns dark quickly
by NavyVet88 - 04/07/20 08:48 AM
Do you eat cold pizza or warm it up?
by ZZman - 04/07/20 08:43 AM
This is the turning point...
by Navi - 04/07/20 07:55 AM
accidental fake fraud
by joaks - 04/07/20 07:10 AM
Anyone here try or use Brickell men's shampoo?
by aquariuscsm - 04/07/20 06:49 AM
Adding A Quart for Mustang GT
by ddhmax1973 - 04/07/20 06:29 AM
Victory 106 C.I. filter replaced. . .
by Robster - 04/07/20 06:09 AM
Monaco GP 1992 Senna/Mansell Battle
by IMSA_Racing_Fan - 04/07/20 03:03 AM
RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
bigboychunky, maleesha2000, baker269, BludRacing, Cacciatore
71119 Registered Users
118 registered members (1978elcamino, 77GrandPrix, alchargo, 53' Stude, Ag76, 12 invisible), 2,522 guests, and 20 spiders.
Topics303,717
Posts5,240,569
Members71,119
Heat Shield Loose #5206276 09/06/19 12:56 PM
SatinSilver Offline OP
On the 05 Matrix towards the rear axle. Kind of by the plastic gas tank. Half of it is hanging down but the exhaust pipe is holding it in place for now. Looks like it's pretty rusted so will need to replace or remove. About 5 years ago and prob 70k miles ago the dealer did a tsb where they replaced the screw in the gas tank strap which connects to the heat shield. It's makes a fair amount of noise esp on start up or when hitting bumps.
Prob prefer to remove it and be done with it but open to suggestions. Any thoughts on this? Thanks in advance!
Re: Heat Shield Loose [Re: SatinSilver] #5206287 09/06/19 01:10 PM
supton Offline
Usually people just let it fall off. On my truck, two of them got loose. I went to the hardware store and bought 2 or 3 different length stainless steel clamps, like the sort used on dryer vents (I think). Put one around it, tightened down, done.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Heat Shield Loose [Re: SatinSilver] #5206354 09/06/19 02:32 PM
J
JC1 Offline
J
I either use a large hose clamp or remove them.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Heat Shield Loose [Re: SatinSilver] #5206387 09/06/19 03:11 PM
I
incognito_2u Offline
I
Old wire clothes hanger
.......cut to size, wrap around pipe and heat shield.
Get your Lineman’s pliers out and twist the ends together the same way you would splice two wires together. When tight, bend the wire up and flush with pipe.
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -91k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Heat Shield Loose [Re: SatinSilver] #5206414 09/06/19 03:59 PM
Cressida Offline
I would keep the shield in place. In addition to the previous suggestions, you can chain link two large zip ties.
I would also check the other heat shields toward the front of the car. In the very first or front shield you may already be missing a bolt or two as they just seem to fall out. You can see these first two bolt positions by getting under the car (near the oil filter) and looking back and up toward the exhaust.
Re: Heat Shield Loose [Re: SatinSilver] #5206449 09/06/19 04:50 PM
K
KrisZ Offline
K
It depends. In a lot of cases the aluminum brakes off around the stud and nut holding the shield. If that;s the case, I successfully, with lots of penetrating fluid, undid them, put oversized washers, and reinstalled the heat shield in the past. Another good method is self taping screws.
But if the nuts and studs broke off, removing the shield on such an old car is probably the next best thing.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Heat Shield Loose [Re: SatinSilver] #5206453 09/06/19 04:54 PM
K
KrisZ Offline
K
Re: Heat Shield Loose [Re: KrisZ] #5206623 09/06/19 08:12 PM
E
eljefino Offline
E
This and this. You forget how quiet your car can be. Lots of people live with the rattle for a long time.
