Originally Posted by hallstevenson
Originally Posted by rubberchicken
In the 2017 Escape with Sync-3 , there is NO way to display the OLM percent. I have been all over it countless times, and had many service guys look into it, and called Ford Customer Support. A buddy of mine is a Ford mechanic and he said the Escape with SYNC-3 will not display it....
This has nothing to do with Sync 2 or Sync 3. Sync 3 is your "center" display's software where you control your audio system, climate control, navigation, etc, etc.
Use the steering wheel controls on the left-hand side of the wheel. From memory, while the car is running, left arrow, then up/down to System Check, then OK, then look for "Oil life...." in the screen.
Sorry but your wrong- for whatever reason on the 2017 Escape , if you have the Sync-3 you will NOT get the Oil Life reading. I am not sure how many times I have to explain this, but that is the limitation. It might be a bug, or they ran out of memory, or an oversight or whatever, but you cannot display % remaining. I am hoping it might be something specific to the 2.0 firmware and the 3.0 restores it, but considering that it should be a completely separate function and limited to the ECM, it makes no sense. Yet here we are- its missing. Trust me, I had numerous service guys and mechanics tell me "its right there", and its not.
