Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
64 registered members (andyd, alarmguy, Astro14, askani79705, anthonym6, aquariuscsm, 8 invisible), 1,551 guests, and 34 spiders.
Topics306,110
Posts5,286,704
Members71,588
85-140w - Power Loss in light Japanese truck #5205875 09/06/19 04:16 AM
Spoonydan Offline OP
My first post, so hi everyone smile
I've got an old 1991 FG 4x4 Mitsubishi Canter truck. 3.3l diesel, formerly non-turbo, but now Turbo smile. 4.5t truck so even turbo it's still a bit slow with an old 3.3l 4cyl soot chucker. It would be lucky to have 110-120hp
While trying to chase a drivetrain whine on recommendation I changed the Transfer and Diff's to Dino 85-140w (previously Dino 80w90)
However I'm now certain it has lost power, in such a vehicle this is most noticed on hills. Ie the ability hold speed or how much speed one looses.
Am I going crazy or it possible the drag of such thicker lube could be noticeable?
The rear diff is LSD front is opened (and not engaged on sealed roads, so out of the picture).
Manual states
Manual Transmission:
Normal region SAE 80 Warm region: SAE 90 (I'm inAustralia so it certainly can get warm)
Transfer:
Rear LSD:
SAE 90 LS
Front:
Below 40DegC(104f): SAE 90 Above 40degC(104f); SAE:140
I've isolated the diff (driveshafts out, centre handbrake to load gearbox/transfer) and it's not causing the whine. I've also pulled the inspection cover off the transfer and it looks really good inside with no play anywhere so it's likely from the gear box.
It'd like to know fluids should I change to ensuring good protection but also minimising drivetrain loss?
I'm thinking splurging and going full-synth.
Given the above specs I'm guessing a 75w85 or 75w90 full synth LS should cover all components OK and reduce drag losses?
Do Synthetics help with gear whine also, or best to try an additive for that?
Brand availability will vary here as we have a number of local producers that make good products (Penrite, Nulon, Gulf Western etc) though stuff like Castrol is still available.
Thanks
Dan
Here the truck/camper smile
Last edited by Spoonydan; 09/06/19 04:19 AM. Reason: censored for saying [censored] Truck haha
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5205943 09/06/19 06:36 AM
A
aquariuscsm Online Content
Online Content
A
Definitely go back to the oem spec W90. I tried a W140 in my 300ZX one time and it caused noticeable drag.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5205962 09/06/19 07:03 AM
Z
zeng Offline
Z
welcome
SAE 90 of the era then would have been in the upper range of between ISO 150 (KV40 of 150 cSt) and ISO 220 (KV40 of 220 cSt) grades .
Depending on brands, a typical 80W90 in Australia would likely come with a KV40 of 135 - 155 cSt which falls on the lower end of spec'ed SAE 90, if not considered out-of-range.
Unfortunately, the drivetrain whine as described demonstrates this viscosity grade is inadequate.
The 85W140 you had ,depending on actual brand, may have KV40 ranging from 250 cSt to say, 360 cSt . Do check what is the actual data sheet KV40 of gear oil in use that gives you a feeling of 'power loss' and pick another gear oil closer to ISO 220.
A typical 75W85 would carry a KV40 ranging from 60 cSt to 70 cSt and IMHO ,is a big no-no in your application.
So is the case with a 75W90 that typically carries a KV40 of 90 -105 cSt.
A 75W140 of typical KV40 of 170 - 175 cSt may be considered, however its shear stability is poor.
I would personally prefer a hard-to-find monograde SAE 110 (KV40 220 cSt) to a common monograde SAE 90 (of KV40 approaching 200 cSt) as both are shear stable.
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206029 09/06/19 08:34 AM
M
mattwithcats Offline
M
Take a look at Final Drive 50...
50 weight SAE, 90 weight gear oil...
Lots of makers, usually full synthetic...
https://www.mobil.com/English-US/Co...GLXXMobil-Delvac-1-Transmission-Fluid-50
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: 85-140w - Power Loss in light Japanese truck [Re: zeng] #5206069 09/06/19 09:05 AM
Cheers for the responses.
aquariuscsm , yeah I will be, it needs ever last baby horse it has haha smile
zeng, the info and detail is great, thanks. I did a bit of a digging on the fluids used so far + other options
Diffs/Transfer:
Nulon 85w140ls Dino with a KV 40 value of 380 , which is beyond even your estimates
(previous Penrite 80w90ls Dino KV40 of 152)
A huge difference, probably explains the power loss.
Gearbox:
Penrite 75w90 SemiSythn with a KV40 of 99
So If I understand you post correctly all the fluids I have in are not really suitable.
Starting at the gearbox, SAE90 is spec'd for warm climates so current fluid (KV40 of 99) falls short?
Researching some products Gulf Western (local producer) seem to offer the best solutions.
They have the following products.
80w90LS Full Synth with a KV of 185
http://www.gulfwestern.com.au/wp-content/uploads/2018/10/Ultra-Clear-Limited-Slip-80W-90-30059.pdf
This seems suitable for the diffs and transfer, would it also be suitable for the gearbox too or would shifting be effected?
I've read that friction modified fluids can cause premature syncro wear and a GL4 is better for gear boxes?
Their GL4 Gearbox full synths are
75w85 with KV69
http://www.gulfwestern.com.au/wp-content/uploads/2015/07/Ultra-Clear-Gear-Oil%C2%AE-75W-85-60050.pdf
or
75w90 with kv100
http://www.gulfwestern.com.au/wp-co...-Clear-Gear-Oil-Low-Vis-75W-90-30056.pdf
They also have a straight 90
LS90 Full Synth KV of 200
http://www.gulfwestern.com.au/wp-content/uploads/2018/10/Diff-Oil-LS-90-30053.pdf
Thanks again.
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206071 09/06/19 09:10 AM
AZjeff Offline
No help here but more pics and specs of your camper are mandatory. Too cool!
And welcome!
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206102 09/06/19 09:51 AM
Z
zeng Offline
Z
Quote
Pardon my English, you're sure the whine is from the manual transmission gear box (which used 75W90) and not from Differential (which used 80W90 previously)?
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206106 09/06/19 09:55 AM
Sam_Julier Online Content
Online Content
I'm glad you posted this.
I just had the differential rebuilt in the 1993 240 wagon. (Dana 30) The shop filled it with dino Phillips 66 85W-140. Volvo spec's 80W-90 GL-5.
I am noticing a loss in power. The diff is also considerably quieter. How much of this is from the rebuild and/or the heavier fluid is hard to say.
I'm considering going to 50/50 mix 80W90/85W145 to see if I notice a difference. And then 80W90.
Sam
2013 Toyota Avalon Hybrid TGMO 0W20, 81k
1993 Volvo 245 T5 10W30, 168k
1993 Volvo 244 T5 10W30, 177k
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206108 09/06/19 09:59 AM
U
umungus1122 Offline
U
No difference I can discern between 90 and 140 gear oils in the vehicles I've owned over the years. shrug
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'04 Crown Vic 95k Maxlife full syn 5w-20
Re: 85-140w - Power Loss in light Japanese truck [Re: umungus1122] #5206112 09/06/19 10:04 AM
Online Content
I wish I could say the same thing. I'm not sure what to make of it.
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206244 09/06/19 12:21 PM
M
meep Offline
M
I have noticed very minor differences in past vehicles, though thinking back, all were manuals. In automatics I've never been able to tell. IDK if I could tell at the throttle or hillclimbs, but noise would be less and the driveline might feel like it had less sloppiness in it... tighter... less backlash.
2018 F150
2015 crv (wifey!)
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206253 09/06/19 12:26 PM
N
nthach Offline
N
That Canter looks awesome, in America these are seen more as a box truck. Why does Oz and Japan have all the cool stuff?
To me, a 75W-90 synthetic gear oil is the way to go in Japanese diffs and they need nothing more than that. If you plan on going out beyond the city limits, maybe 75W-140 that's used in Fords might be a better pick.
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206317 09/06/19 01:44 PM
B
benjy Offline
B
going from OE 75-140 semi syn to 75-90 redline real synthetic in the rear of my 2011 Frontier SV 4WD + the rest of the drivetrain lubes to redline real synthtic netted me about 3MPG!!
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206455 09/06/19 04:58 PM
Interesting insights, it certainly seems I'm not alone in noticing an overly thick gear oil. Probably more pronounced in what is a quite a large diff (more fluid/bigger gears) combined with a heavy vehicle and very little power.
For those interested in the Truck, it was built as a camper back in 1991 and has lived it's life travelling Aus. The camper body is full moulded fibreglass. I bought it for the platform and and have working on it the past year for the aim to rent the house and travel Australia for a couple of years with my dog.
A bunch of spam pics for those interested smile
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: 85-140w - Power Loss in light Japanese truck [Re: Spoonydan] #5206629 09/06/19 08:20 PM
AZjeff Offline
The truck is amazing, it looks like it has been well kept and there are some obvious recent additions, the lights obviously. What's the purpose of the screens in front of the windshield? What kind of range do you have on a full tank?
Now about your dog, what is he? We have an 8 year old blue ACD male and a 1 year old red supposedly ACD female. The male is classic cattledog but the female has been a bit of mystery as she sure doesn't look like him but she sure looks like your dog. Her ears are oversize and never stood up but she looks like your guy, same short coat and she even does the same sit up thing completely on her own. Sorry for the side track, awesome truck and dog you've got.
[Linked Image]
