Effective ways to reduce humidity inside the car
by MoneyJohn - 12/12/19 08:21 AM
Stupid regulations- Diesel Cap Color
by Rmay635703 - 12/12/19 08:20 AM
Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
Old school bra
by whizbyu - 12/12/19 07:10 AM
Tricky flight ticket change fees
by Superflan - 12/12/19 07:10 AM
2019 Jeep Rubicon F&R Axle UOAs [5,000 Miles]
by 2015_PSD - 12/12/19 06:58 AM
Redline SL-1. Application warning
by BMWTurboDzl - 12/12/19 06:51 AM
My Forester CVT blew up
by IMPALA08 - 12/12/19 06:30 AM
2016 Titan XD Cummins, Schaeffers 9000 5W-40
by 06_lx - 12/12/19 06:09 AM
Will moving steering via wheel hubs cause harm?
by mobilaltima - 12/12/19 12:26 AM
This oil looks interesting but not avail in US
by jkhawaii - 12/11/19 10:39 PM
Castrol Engine Shampoo (Oil Flush)
by adams355 - 12/11/19 10:03 PM
How Dumb can she get #2
by KeithS_NW_Ohio - 12/11/19 09:45 PM
Dodge Transmission
by Butterbean - 12/11/19 09:38 PM
Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
lutvi20, Bazik, Lamasuna, berlinbai, SimpleGuy48
70111 Registered Users
95 registered members (ARCOgraphite, alphadog, Alfred_B, 14Accent, Aero540T, alcyon, 7 invisible), 1,565 guests, and 20 spiders.
Topics298,617
Posts5,139,211
Members70,111
Most Online3,589
Nov 2nd, 2019
Starter Replacement in 2012 Frontier #5205625 09/05/19 05:30 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I just had my starter replaced in my 2012 Frontier with a Duralast starter.
Let's hope the Duralast outlasts the OEM part. shocked2
The solenoid would pull in (you could hear the click) but no cranking.
Luckily it died in the driveway so the tow truck had no problem lifting it.
It is located close to exhaust parts and even though there are two heat shields, it must have become, "cooked."
BBQed starters don't look or operate so well. grin2
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205641 09/05/19 05:52 PM
U
user52165 Offline
U
"Let's hope the Duralast outlasts the OEM part."
Never happen. OEM is best.
Dis you consider fixing it? Often simple and cheap.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205655 09/05/19 06:07 PM
A
andyd Offline
A
7 yr old original starter isn't awful. Have you turned the old in for core charge or are you gonna get it rebuilt?
Thick oil is better grin2
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205662 09/05/19 06:18 PM
T
Trav Offline
T
Yes, they are rebuildable at home but only if the field winding insulation didn't get cooked and short which is very possible from what you describe. Armature winding are usually okay unless the commutator get damaged but that is replaceable too a simple growler test will check it..
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205672 09/05/19 06:37 PM
M
maxdustington Offline
M
Frontier = BITOG's truck!
99 Toyota Tercel CE 5EFE/C151
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205685 09/05/19 06:48 PM
K
kc8adu Offline
K
iirc the contacts fail.
a set is $10 shipped.
easy to replace.
some just flip the main one over and use it up.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205750 09/05/19 08:23 PM
1
14Accent Online Content
Online Content
1
Good luck with the Duralast... had a customer in today that had their starter replaced a week ago with a white-box starter at another shop. Already junk.
I will only use one of those when the customer asks for the cheapest of the cheap. Otherwise, I go to my local rebuilder every time for starters and alternators.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205756 09/05/19 08:33 PM
L
Lolvoguy Offline
L
Nothing grinds my gears more than short-sighted designs like that.
My Focus had the same issue but with the alternator mounted at the back of the engine, with the exhaust mani right below it.
Luckily I disposed of the car before it required replacing.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205884 09/06/19 03:58 AM
P
Popsy Offline
P
7 years isn't too bad IMO.
For sure they don't last as long as before, but like you say the location plays a big role...and new engines/cars with packed engine bay and high power density engines don't help.
My 23 and 21 yo Fiats have the starter sitting almost at the bottom rear of the engine, the diesel is still on the OEM Magnetti Marelli starter, but the Barchetta got a new Bosch starter recently.
The rebuilder told me it wouldn't have been worth a rebuild, now I'm unsure about that! The geared crown/pinion that engages into the flywheel (worry for bad English) was very worn out and they couldn't locate a suitable replacement.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5206286 09/06/19 12:09 PM
Silverado12 Offline
I had a 1996 Chevy S-10 4 cyl that ate starters for the same reason. The exhaust manifold had to come off to access the starter.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Starter Replacement in 2012 Frontier [Re: user52165] #5206466 09/06/19 04:18 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I usually rebuild all of our starters and alternators, but in this case I needed to lift it high enough to remove all of those heat shields and have enough room for removal, but did not have the lifting capability so I had my mechanic change it.
BTW, this is a geared and rather small size starter with a permanent magnet field system. So it still has brushes to energize the rotating armature. It turned out the brushes were ok but worn, but the wiring in the armature had shorted.
Charlie Eppes:
Re: Starter Replacement in 2012 Frontier [Re: Silverado12] #5206470 09/06/19 04:21 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I have a 1999 S-10 V6 that is on its second starter.
Charlie Eppes:
