And so it begins. Winter 2019-2020.
by DejaVue - 12/11/19 12:13 AM
reference for tires wearing faster when new?
by NissanMaxima - 12/10/19 10:46 PM
2.4L GDI Turbo available?
by 2014_K5_Optima - 12/10/19 10:08 PM
rotary compressor breathing air
by MasterBlaster - 12/10/19 09:33 PM
Substitute for Polaris hub oil?
by The_Eric - 12/10/19 08:53 PM
'20 Hyundai Sonata -- Wow-ee! Looks!
by paoester - 12/10/19 07:11 PM
2021 Chevrolet Suburban and Tahoe Revealed
by E365 - 12/10/19 06:56 PM
Do you try to book on widebodies?
by fdcg27 - 12/10/19 06:25 PM
Carbon Farming
by SubLGT - 12/10/19 05:40 PM
How Many Vehicles Do You Maintain?
by Passport1 - 12/10/19 04:23 PM
Bypass Setting vs Subaru
by Al - 12/10/19 03:10 PM
13 chevy equinox I4 engine oil in filter box
by Fitter30 - 12/10/19 02:04 PM
Driven - Direct Injection Oils
by buster - 12/10/19 01:59 PM
.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
The forgotten Bolens 1253
by Lubener - 12/10/19 11:49 AM
Valvoline High Mileage vs Valvoline Full Synthetic?
by Bettez88 - 12/10/19 10:33 AM
Bruce147, snowplow, Rovingcowboy, 2014_K5_Optima, Peter_Tremonti
70098 Registered Users
27 registered members (AdRock, 4WD, bubbatime, 08z06, Benjamin963, BlakeB, 3 invisible), 724 guests, and 29 spiders.
Topics298,557
Posts5,138,058
Members70,095
Most Online3,589
Nov 2nd, 2019
Starter Replacement in 2012 Frontier #5205625 09/05/19 05:30 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I just had my starter replaced in my 2012 Frontier with a Duralast starter.
Let's hope the Duralast outlasts the OEM part. shocked2
The solenoid would pull in (you could hear the click) but no cranking.
Luckily it died in the driveway so the tow truck had no problem lifting it.
It is located close to exhaust parts and even though there are two heat shields, it must have become, "cooked."
BBQed starters don't look or operate so well. grin2
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205641 09/05/19 05:52 PM
U
user52165 Offline
U
"Let's hope the Duralast outlasts the OEM part."
Never happen. OEM is best.
Dis you consider fixing it? Often simple and cheap.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205655 09/05/19 06:07 PM
A
andyd Offline
A
7 yr old original starter isn't awful. Have you turned the old in for core charge or are you gonna get it rebuilt?
Thick oil is better grin2
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205662 09/05/19 06:18 PM
T
Trav Offline
T
Yes, they are rebuildable at home but only if the field winding insulation didn't get cooked and short which is very possible from what you describe. Armature winding are usually okay unless the commutator get damaged but that is replaceable too a simple growler test will check it..
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205672 09/05/19 06:37 PM
M
maxdustington Offline
M
Frontier = BITOG's truck!
99 Toyota Tercel CE 5EFE/C151
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205685 09/05/19 06:48 PM
K
kc8adu Offline
K
iirc the contacts fail.
a set is $10 shipped.
easy to replace.
some just flip the main one over and use it up.
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205750 09/05/19 08:23 PM
1
14Accent Offline
1
Good luck with the Duralast... had a customer in today that had their starter replaced a week ago with a white-box starter at another shop. Already junk.
I will only use one of those when the customer asks for the cheapest of the cheap. Otherwise, I go to my local rebuilder every time for starters and alternators.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205756 09/05/19 08:33 PM
L
Lolvoguy Online Shocked
Online Shocked
L
Nothing grinds my gears more than short-sighted designs like that.
My Focus had the same issue but with the alternator mounted at the back of the engine, with the exhaust mani right below it.
Luckily I disposed of the car before it required replacing.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5205884 09/06/19 03:58 AM
P
Popsy Offline
P
7 years isn't too bad IMO.
For sure they don't last as long as before, but like you say the location plays a big role...and new engines/cars with packed engine bay and high power density engines don't help.
My 23 and 21 yo Fiats have the starter sitting almost at the bottom rear of the engine, the diesel is still on the OEM Magnetti Marelli starter, but the Barchetta got a new Bosch starter recently.
The rebuilder told me it wouldn't have been worth a rebuild, now I'm unsure about that! The geared crown/pinion that engages into the flywheel (worry for bad English) was very worn out and they couldn't locate a suitable replacement.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Starter Replacement in 2012 Frontier [Re: MolaKule] #5206286 09/06/19 12:09 PM
Silverado12 Offline
I had a 1996 Chevy S-10 4 cyl that ate starters for the same reason. The exhaust manifold had to come off to access the starter.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Starter Replacement in 2012 Frontier [Re: user52165] #5206466 09/06/19 04:18 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I usually rebuild all of our starters and alternators, but in this case I needed to lift it high enough to remove all of those heat shields and have enough room for removal, but did not have the lifting capability so I had my mechanic change it.
BTW, this is a geared and rather small size starter with a permanent magnet field system. So it still has brushes to energize the rotating armature. It turned out the brushes were ok but worn, but the wiring in the armature had shorted.
Charlie Eppes:
Re: Starter Replacement in 2012 Frontier [Re: Silverado12] #5206470 09/06/19 04:21 PM
MolaKule Offline OP
Global Moderator
Global Moderator
I have a 1999 S-10 V6 that is on its second starter.
Charlie Eppes:
