I have this old Craftsman 1 gallon compressor that I like to keep handy for using pneumatic nailers for random jobs. It wasn't holding pressure so I did a soapy water test and found 2 leak points. The relief valve has a leak and the regulator has a leak.
I can just buy replacement parts and swap these out right? Below I found some online examples of what I'd buy, but I'll check my local Harbor Freight first because they seem to have a really good selection of air tool parts.
Relief valve only: https://www.amazon.com/Control-Devices-Brass-Safety-Pressure/dp/B0081TJJDG
Or this entire unit pressure control/relief valve: https://www.amazon.com/Central-Pneumatic-Compressor-Pressure-Replacement/dp/B07WYWWXDC
Regulator manifold: https://www.amazon.com/Craftsman-1000000274-Compressor-Manifold-Assembly/dp/B009YERXDA
