Any common issues to be aware of? Car is a 2015 model. 35K miles on it. Aware of plugs and DSG service upcoming.
Religiously change DSG fluid at 40k using OE VW.
I am not aware that spark lugs on EA888 are due that early unless it is something specific to this Audi.
It's per Audi's data:
https://www.audiusa.com/content/dam...ntenance-Schedule-Model-Year-2015-v2.pdf
I'm just going by that, and yes, I also am aware DSG needs to be driven like a stick in traffic, not like an automatic. If this is adhered to (she "gets it"), and the fluid is changed on time, by Audi, is it a good box that should last 200K, or is that just pie in the sky?
I am not aware of DSG being driven like manual. In which sense? Manually shifting? It is not necessary.
DSG's had occasionally mechatronics issue up until mid 2012. My 2010 VW CC that I traded with some 116k never had a single issue. But again, I did change fluid every 40k.
So spark plugs at 35k is bcs. engine is flex fuel? My EA888 in Tiguan is at 60k.
It says it's flex fuel. Can it run on 87 octane, or nah?
Also...
As to DSG's, I have been under the impression that you do not want to "creep" in them, because it's the same as riding a clutch in a manual. You want to either be accelerating or steady, or stopped. Not this creep at 1mph business. Hence, "drive it like a manual". You wouldn't ride the clutch at 1mph in a traffic jam in a stickshift, so why make the DSG do the same thing? Or is my info dated?
