Originally Posted by Oldswagon
I should clarify that this is a 2008 Tundra with over 140K on it and I have owned it for most of its life. So warranty is not an issue. I want to use synthetic because of the cold weather I see, as cold as -40 on a rare occasion. It also doesn't see heavy towing or get dipped in the lake. When I launch my boat I never go that far into the water.
I just wanted input on whether I could extend the Toyota recommended interval. I would think synthetic would offer I increased longevity. Ì admit, I did run the front diff and transfer case about 50K miles and they seemed pretty clean when I dumped them last week. I have dumped the rear end every 30k, because it gets used a lot more. This last time the oil looked almost new coming out. So I was thinking 50K might be good for both.
And yes, I owned several vehicles in the past where the dinosaurs gear oil was never changed.
Originally Posted by wagsrk08
I would think it would be in your best interest to maintain the Toyota OCI in your differentials & transfer case (transmission too). Earlier this year I changed my front/rear differentials with Redline 75W85 GL-5 gear oil (2012 Tacoma 4cyl 4x4). Used Redline MT 75W90 GL-4 in both manual transmision & transfer case. I went with what Toyota recommended on oil weights & GL ratings. Since I never tow anything with my Tacoma (30,000 mi towing OCI), I didn't do these changes until 80,000 miles. All the fluids looked great other than front differential which had a light tint (water or broken down). Next time around I'll change @ 45,000 miles since fluids looked great and I still won't be towing. And yes, Redline products are not cheap. But I'll use them again.
So you tell me to stick to 30K OCI, but you did extend your and will continue to do so?
Your opening post was vague. Now we know your vehicle is 11 years old with 140,000 miles. You don't heavy tow, and you've owned your Tundra most of it's life. As far as I knew from get go your vehicle was fairly new, possibly under warranty and low miles. With this new information you've provided I'd extend it out to 45K. And yes use synthetic fluids. My Toyota owners manual recommends synthetic gear oil.
