Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
Removing transferred dye?
by aquariuscsm - 02/17/20 08:53 AM
ST 0W-20 2013 Sienna 100k
by Mangos86 - 02/17/20 08:43 AM
Starter/Generator bearing grease
by puma4440 - 02/17/20 08:04 AM
I Did Buy the 4Runner 3.4 V6 w/253,000 miles
by Speak2Mountain - 02/17/20 07:59 AM
Proper Brake Bleeding Sequence
by Gebo - 02/17/20 07:32 AM
Do new Jeeps have death wobble?
by supton - 02/17/20 07:21 AM
New to me 2014 Passat TDi- T6?
by racin4ds - 02/17/20 07:07 AM
Chemtech Fuel Additive
by momo - 02/17/20 06:36 AM
Hydraulic oil filter cross reference
by shibby6600 - 02/17/20 01:13 AM
War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
JimMorrison, bjfangjd, 45ander5, FlightRT, 74Widebody
70724 Registered Users
102 registered members (1978elcamino, alchargo, AandPDan, allepunta, 53' Stude, 13 invisible), 2,378 guests, and 19 spiders.
Topics301,560
Posts5,198,098
Members70,724
2017 L5P Duramax Fuel Filter (TP1015) #5204103 09/03/19 10:02 PM
B
BlakeB Offline OP
B
12,852 miles
522.4 engine hours
DIC fuel filter life was ran down to 0%.
The L5P fuel filter is much easier to change than LML and prior Duramax fuel filters that were behind the passenger side fender liner. All you need to change the L5P fuel filter is a 36mm socket and a pick to change the 2 o-rings. It takes about 10 minutes to change the filter and the fuel system bleeds itself when you cycle the key a few times. The older Duramax engines did not have a lift pump and had to be bled manually. The OEM TP1015 can be had on Amazon or eBay for ~$20-$25 each.
[Linked Image]
Re: 2017 L5P Duramax Fuel Filter (TP1015) [Re: BlakeB] #5204159 09/04/19 02:08 AM
SteveG4 Offline
That's dirty! Good to hear it's easy to change and see it changed out. smile
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: 2017 L5P Duramax Fuel Filter (TP1015) [Re: BlakeB] #5212376 09/14/19 09:58 AM
DoubleWasp Offline
That and the lift pump make it a much smarter design.
