Been experiencing some cooling issues with my '01 Grand Marquis over the course of the last several months. I have a 180°F thermostat with the cooling fan programmed to turn on full blast once coolant temperature hits 206°F. Once up to operating temperature, coolant temperature is barely under 211°F. What's more worrying is ATF temperature, which shot up to 230°F in traffic. The AC isn't cooling as well as it should either.
I haven't really heard the fan on full blast for a while, and you don't feel as much air being pulled by the fan. I decided to swap the cooling fan's high relay with a spare one I had, same result. The other thing I noticed was on a cold engine, the fan's connector gets hot after a minute or two of operation. The connector is not burnt or anything, there are no codes stored in the PCM.
The Bosch fan motor is the factory original, but if the fan was the culprit, would it still work on the low speed setting?
