wemay
Site Donor 2023
https://www.autoserviceworld.com/quaker-state-adds-to-its-line-of-synthetic-motor-oil/
Quote
Quaker State is launching two new synthetic motor oils, High Mileage (for vehicles with more than 120,000 kilometers) and Ultimate Durability Euro Full (for European engines).
Quaker State says its High Mileage Full Synthetic motor oil offers more wear protection and pumpability to increase engine life and performance. It also helps prevent leaks and reduces motor oil burn off. A suite of additives offer protection against harmful deposits that may form as the age or mileage increases.
This motor oil exceeds the requirements of API SN PLUS, API SN and ILSAC GF-5 industry specifications and will be available for purchase at retailers across Canada in September 2019 in the following viscosity grades: SAE 0W-20, SAE 5W-20 and SAE 5W-30..
Quaker State Ultimate Durability Euro Full Synthetic motor oil helps to protect modern, turbocharged European engines against wear, the formation of sludge and deposits, and heat-activated viscosity improves help to maintain oil thickness, all designed to extend engine life and provides more performance.
This motor oil will be available for purchase at retailers across Canada in October 2019 in the following viscosity grades: SAE 5W-40, LX SAE 0W-30 and L SAE 5W-30.
www.quakerstate.ca
Quote
www.quakerstate.ca
