Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Tractor Supply more Mobil 1 clearance
by jayjr1105 - 02/24/20 10:51 AM
BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
zip15, PeterNST, SkinnRS, Bama65, wjamyers
70794 Registered Users
116 registered members (abspare, 330indy, 4WD, 1978elcamino, 2015_PSD, 2009Edge, 6 invisible), 2,183 guests, and 21 spiders.
Topics301,873
Posts5,204,346
Members70,793
Star Tron Ring Clean #5203515 09/03/19 09:02 AM
StarCaller Offline OP
just wondering if anybody ever gave this cleaner a shot?
amazon reviews from the boating community are not bad.
[Linked Image from i.postimg.cc]
Re: Star Tron Ring Clean [Re: StarCaller] #5203520 09/03/19 09:17 AM
H
Highboy Offline
H
I’m using this on a 2008 Scion tC oil burner. About half a bottle in and my son just started school, so I’ll watch for any change now that it’s driven more.
2006 Scion tC ST/Oem filter
2008 Scion tC ST/Oem filter
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
2019 Subaru WRX
Re: Star Tron Ring Clean [Re: StarCaller] #5203563 09/03/19 10:26 AM
L
Linctex Offline
L
Yamaha makes a special ring cleaner additive for their outboards....
I wonder if this is a similar formulation?
Doesn't the WHOLE REASON the product "Sea-Foam" exists in the first place was as an outboard engine cleaner?
Re: Star Tron Ring Clean [Re: StarCaller] #5203566 09/03/19 10:29 AM
Donald Offline
StarTron is a reputable company in the boating world.
My question is does it clean all 3 rings or just the top one. An oil burner will typically have an issue with the lower ring, oil control ring (assuming its not bad bearings or something else causing the oil burning). Not sure how much fuel will get there with this stuff mixed in.
2015 Ford F-250 w/Powerstroke
Re: Star Tron Ring Clean [Re: StarCaller] #5203710 09/03/19 01:33 PM
MolaKule Offline
Global Moderator
Global Moderator
Is this for a boat engine or Vehicle/Light truck application?
I'm a Student Pilot. Frightening, isn't it?
Re: Star Tron Ring Clean [Re: MolaKule] #5203718 09/03/19 01:44 PM
2014 prius /
they have sometimes problems with coked rings, which eventually leads to head gasket failure /
gotta do pretty much everything to avoid this....
Re: Star Tron Ring Clean [Re: Donald] #5203759 09/03/19 02:51 PM
T
Trav Offline
T
Only leaking oil past the pistons or guides for numerous reasons or drawing oil in from a blown gasket or turbo seal into the combustion chamber causes oil "burning", bearings, camshafts, etc play no role in it.
Re: Star Tron Ring Clean [Re: StarCaller] #5203776 09/03/19 03:25 PM
K
krismoriah72 Offline
K
Subaru has an upper engine cleaner, Honda does, Polaris has an upper engine cleaner, Yamaha has an upper engine cleaner, GM has an upper engine cleaner, Mopar does too.
But most of these are sprayed into the combustion chamber while running via aerosol.
For what you have pictured, i would rather use Redline Si-1. "Cleans injectors, carburetors, valve and combustion chamber deposits with a concentrated blend of the most powerful high-temp and low-temp detergents available Cleans all forms of fuel injectors, including GDI....
Re: Star Tron Ring Clean [Re: StarCaller] #5204338 09/04/19 07:50 AM
W
wag123 Offline
W
I have serious doubts about this product. Why? Because they claim that it has enzymes. Enzymes are biological molecules (typically proteins), in other words, they are something that can't survive in a petroleum/solvent environment.
Re: Star Tron Ring Clean [Re: wag123] #5204576 09/04/19 01:41 PM
Re: Star Tron Ring Clean [Re: krismoriah72] #5204967 09/05/19 01:01 AM
Marco620 Offline
Agree!! Could be used in conjunction with a pea based throttle body spray like crc GDI or royal purple.
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Star Tron Ring Clean [Re: StarCaller] #5205060 09/05/19 05:52 AM
W
wag123 Offline
W
Originally Posted by StarCaller
OK then, assuming that enzyme molecules can be made to survive in petroleum gasoline, what about their ability to survive the heat and pressure of combustion?
Re: Star Tron Ring Clean [Re: StarCaller] #5205113 09/05/19 07:13 AM
touché /
you got me with this one; didn't think about that /
if nething in this stuff cleans the rings, for sure it's obviously not enzymes /
Re: Star Tron Ring Clean [Re: wag123] #5205592 09/05/19 04:50 PM
M
Mad_Hatter Offline
M
At up to 4500f, not much will survive the combustion chamber. And do you really want an additive surviving the combustion process? (anything hard has the potential to scar) I think even PEA gets annihilated in the process but in the nano seconds before combustion the atomized PEA attaches itself to any carbon in the chamber and the heat activates it and the carbon flakes off and exits via the exhaust valve.
Not sure if "activates" is the right term but it has something to do with heat making/allowing PEA to work better at removing carbon than other additives like PIBA, which is normally used in cheaper cleaners like a FI alone cleaner.
Re: Star Tron Ring Clean [Re: StarCaller] #5206561 09/06/19 05:53 PM
MolaKule Offline
Global Moderator
Global Moderator
I don't see anything in this paper to support carbon removal in Internal Combustion engines.
