Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
72 registered members (1foxracing, 2003f7, andyd, 2015_PSD, alarmguy, anthonym6, 11 invisible), 1,595 guests, and 30 spiders.
Topics306,110
Posts5,286,708
Members71,588
Loctite 5970 RTV #5203499 09/03/19 09:34 AM
The Critic Offline OP
This is kind of a silly post. I apologize in advance.
Most of the Euro OEM’s call for this RTV on timing covers and oil pans. I recently used the product to reseal an upper timing cover on a C250 and an oil pan on a C300 without issues.
However, I found this RTV to be “weaker” than Toyota FIPG Black or HondaBond HT. After curing, it is more easily removable from surfaces than I expected. If I leave a bead of 5970 squeezed out of the applicator nozzle (so that I can reuse the nozzle for the next use), this rtv is so soft that the bead will just fall out of the nozzle.
Yes, I verified that both tubes were not expired.
I am not used to working with RTV that displays these properties. Is this normal for Euro RTV’s?
https://dm.henkel-dam.com/is/content/henkel/12990_Henkel-SellSheet-Loctite-5970-EN-28_9_15pdf
(Note about the picture: When I ordered Loctite 5970 from SSF, they sent a tube that was sold under the MB label.)
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Loctite 5970 RTV [Re: The Critic] #5203616 09/03/19 12:34 PM
T
The_Eric Offline
T
I've seen a similar product in powersports engines - usually 3 Bond of some kind and it always seems to work okay. As long as the surfaces are rigid and clean, you'll be fine.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Loctite 5970 RTV [Re: The Critic] #5204078 09/03/19 10:06 PM
clinebarger Offline
You need a stick of dynamite to get parts separated when using Toyota FIPG Black....Assuming everything is cleaned & prepped well.
Sounds like a softer "Packing".....Which is fine if it works well at it's intended usage. Some of these parts expand & contract with heat cycles thus the need for packing to be more pliable.
2001 Chevy Camaro L92/4L80E
Re: Loctite 5970 RTV [Re: The Critic] #5204091 09/03/19 10:27 PM
R
red7404 Offline
R
i like permatex # 2. i found RTV wants to slide around be for it sets.
Re: Loctite 5970 RTV [Re: The Critic] #5204127 09/04/19 12:10 AM
M
Mad_Hatter Offline
M
The applicator plastic used is designed to resist adhesion for starters and Loctite 5970 uses a unique type of silicone designed to provide better flexing performance (where movmt, even micro movmt, between the two parts is of particular concern) over traditional silicone RTV's, so it doesn't cure as rigid as something like a Permatex blk/gry.
Re: Loctite 5970 RTV [Re: clinebarger] #5204143 09/04/19 01:38 AM
Interesting - thanks guys.
Re: Loctite 5970 RTV [Re: The Critic] #5204199 09/04/19 05:28 AM
M
Mad_Hatter Offline
M
NP... that 5970 is good stuff. I'll have to keep it in mind the next time I need an rtv.
Re: Loctite 5970 RTV [Re: The Critic] #5232934 10/07/19 12:50 PM
I have an extra tube of this stuff that is brand new. Does anyone want it?
