MolaKule
Staff member
For those of you not Amateur Radio Operators you can still listen in to the Hurricane Emergency Networks
Main Frequency is: 7.268 MHz
Hurricane watch net DORIAN 40 meter: 7.268 MHZ Link (7.268 MHz Link, Lower sideband)
Another Frequency is:
Hurricane watch net DORIAN 20 meter: 14.326 MHz Link (14.326 MHz Link Upper sideband)
The Waterway Net and Maritime Mobiles net is on 80 meters at 3.815 MHz Lower sideband
The North Florida Net is on 3.950 MHz with the South Florida Net at 3.940 MHz (Both on 80 meters) Lower sideband.
You control the Mode (LSB or USB) with the Pushbuttons and enter the frequency in the Green Panel, then Return.
The Band in meters is above the green Frequency panel. For example, 7268 or 7268.00 is 7.268 MHz
and 14326 is 14.326 MHz.
