Is anyone using something like this? It's getting close to Fall oil change time, and I still haven't figured out what I'm going to do ramp wise.
https://www.walmart.com/ip/Stark-Dr...ve-Hydraulic-Lift-Repair-Frame/275017861
They're a little on the expensive side at $3 bills a pair, but it looks like a good idea because it gives you a shallow enough drive up angle. But also allows you to get the vehicle as high as you need it by employing the built in jacks. It would be easier than jacking the car up from the get go and using stands, because the ramp itself gives you some fairly good height.
And jacking up a lot of these unibody frame cars are a PITA, because all of the jacking points are irregular, with sharp seamed edges that can fall off the jack easily. I struggled with my Jeep trying to get the thing on jack stands to rotate the tires. I sure don't want to go through that hassle every time I change oil. My Toyota is even worse. It has so much low plastic trim, I don't trust most of the ramps because of the high drive up angle. Along with them not getting the car high enough. And no one is going to let you, "try them before you buy them".
So it comes down to either spending the money, and being done with it. Or else screwing around creating another project by buying stud lumber, hauling it, sawing it up and getting sawdust everywhere, then buying screws and screwing it all together. I just thought I'd check in and see if anyone has a pair of these, and if so what they thought of them? Sometimes things that look good aren't always so practical when you go to use them. On the other hand if they work, I would rather simply part with the money, instead of creating another PITA project to deal with.
