using vinegar to flush cooling system
by old1 - 07/06/20 02:11 PM
Best lube for refrigerator door hinges?
by paulri - 07/06/20 01:11 PM
RIP Ennio Morricone
by 2015_PSD - 07/06/20 12:49 PM
What oil do you recommend?
by BretBouer - 07/06/20 12:36 PM
NAPA Synthetic / Filter Sale
by WyrTwister - 07/06/20 12:16 PM
Squished Stihl MS 181
by Gebo - 07/06/20 12:14 PM
Used Review- '17 Nissan Armada Platinum
by panthermike - 07/06/20 11:53 AM
RIP Charlie Daniels.
by PimTac - 07/06/20 11:34 AM
Transmission fluid change
by dan765 - 07/06/20 10:53 AM
Toyota LL or SLL in a Ford?????
by TacoFergie - 07/06/20 10:52 AM
Pulling a vacuum to remove water
by Donald - 07/06/20 10:42 AM
03 4.7 Durango - AC System
by joshuawesl - 07/06/20 10:40 AM
19 4Runner M1 0w40 11k oci
by Doublehaul - 07/06/20 10:11 AM
Fiberglass Garage Door
by Al - 07/06/20 09:57 AM
EcoGard x4615 can l "use it with confidence"?
by Joe1 - 07/06/20 09:43 AM
Bearing issues on rebuilt engine
by Mullady76 - 07/06/20 08:57 AM
Portable tire inflator
by RoyClark - 07/06/20 08:52 AM
Air filter maintenance
by nomas - 07/06/20 08:41 AM
Great Deals At NAPA
by Mathew_Boss - 07/06/20 08:40 AM
AnotherPerson, biomatrix, CDN, KeyzzDzz, carms
71858 Registered Users
109 registered members (911Don, 77GrandPrix, A310, 2015_PSD, 379KITTY, 4WD, 14 invisible), 2,327 guests, and 24 spiders.
Topics307,492
Posts5,312,131
Members71,858
Page 2 of 2 1 2
Re: Best Chassis Grease [Re: Bdsankey] #5200264 08/29/19 10:30 PM
Snagglefoot Online Content
Online Content
When in Canada:
If you want the job done right......do it yourself.
Re: Best Chassis Grease [Re: OILJUNKIE] #5200452 08/30/19 08:23 AM
B
Bdsankey Offline OP
B
Originally Posted by OILJUNKIE
The best grease is the one you use every 2 months. Which is what 90% of vehicle owners don't do. The last time I took my truck to the dealer for service the service writer told me my truck did not have grease fittings. I had been greasing them for the last 4 years. I was on vacation and did not have my grease gun.
I completely agree. I grew up working in my father's auto garage and have seen the horror/lack of care given at dealerships/quick lubes. I am very OCD about maintenance. I used to change my synthetic motor oil in my diesel every 5k miles simply because I've done it for the past two decades until I decided to try extending intervals. Currently I am at ~9k on my oil fill with the next sample point at 15k and all looks well but that is another story.
If 229 #2 won't give me issues I will just stick with that. I know it states not recommended for wheel bearings but how closely do universal joints with needle bearings mimic the greasing requirements of a roller ball wheel bearing? I currently only have 1 grease gun but if I am going to do more damage then I will pick up a second and fill with an appropriate grease.
Current Rides:
Toy: 2005 Chevrolet Silverado 2500HD, Duramax Diesel (LLY)
DD/Tow Rig: 2002 Chevrolet Silverado 2500HD, Duramax Diesel (LB7)
Re: Best Chassis Grease [Re: Bdsankey] #5200566 08/30/19 10:59 AM
Q
qdeezie Offline
Q
I recently did a complete rebuild on the front end of my 2003 Ford Focus and installed parts with grease fittings (as opposed to the non-greasable factory parts). I see the recommendations of every 2 months or every 2,500 miles on this thread, which is what I will adapt moving forward.
My question is how many "squirts" of grease is ideal for each fitting type? Or are there other factors that dictate how much grease is needed?
Any information that can help to best maintain the new front end and suspension parts would definitely be appreciated.
'90 F150 XLT Lariat
'13 Hyundai Elantra Coupe SE
'03 Ford Focus ZX3
'06 F150 King Ranch
Re: Best Chassis Grease [Re: Bdsankey] #5200908 08/30/19 06:48 PM
T
TheLawnRanger Online Content
Online Content
T
Master Pro Hi Temp Disc Brake/Wheel Bearing Grease
2011 Impala
2012 Colorado
2018 Buick Encore
Oil: 5w30 synthetic
Re: Best Chassis Grease [Re: Bdsankey] #5202582 09/02/19 06:55 AM
R
Rob_Roy Offline
R
In a wheel bearing application a very tacky grease can curl around the spindle between the bearings rather than staying in the bearings as intended. If you are just using the 229 for general chassis lubrication, it should be fine.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Best Chassis Grease [Re: Jimzz] #5202588 09/02/19 07:11 AM
rsylvstr Offline
That’s what I use on everything.
Mower spindles.
Chassis.
Whatever.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Best Chassis Grease [Re: Bdsankey] #5202591 09/02/19 07:14 AM
rsylvstr Offline
Next in the tube is Lucas Red and Tacky #2 multi purpose grease.
Hoping it is compatible with the Valvoline above.
No grease points on the truck but the trailer bearings and mower do.
Re: Best Chassis Grease [Re: Bdsankey] #5202618 09/02/19 07:57 AM
T
tundraotto Offline
T
My vote for best chassis grease would have to go to DELO EP-2 ESI.....highest timken load rating I have seen. LB rating only though for some reason.
Re: Best Chassis Grease [Re: Bdsankey] #5202831 09/02/19 01:51 PM
R
Rob_Roy Offline
R
Their product sheet mentions wheel bearing use. Odd that it is not GC rated.
1999 Ford F350, V10
Re: Best Chassis Grease [Re: Rob_Roy] #5202868 09/02/19 02:35 PM
T
tundraotto Offline
T
I know right! Pictures and wording of bearings everywhere in the tube and literature. I bought it to replace the GC-LB Supertech Red I was using as I was down to my last tube and was very disappointed to not see a GC-LB certification....bought a new grease gun.
Someone mentioned that it was possibly due to not low enough low-temp capabilities....but that doesn't apply to my location - I needed the high temp/high scar more.
Re: Best Chassis Grease [Re: Bdsankey] #5203023 09/02/19 06:08 PM
A
AnthemBassMan Offline
A
I just use Mystik JT-6 No. 2 hi-temp red grease on pretty much everything. It’s also a GC-LB 80# rated grease and you can find it in virtually every store where you’d buy oil or grease.
[Linked Image]
L8R,
Matt
2010 Chrysler Sebring Touring 197kmiles
Valvoline HM Maxlife full synthetic/SuperTech ST10060 filter
2017 Hyundai Elantra SE 49k miles
Pennzoil Platinum 5w30/Fram Ultra XG9688 filter
Re: Best Chassis Grease [Re: Bdsankey] #5203396 09/03/19 06:45 AM
B
Bdsankey Offline OP
B
As an update, I checked what the case at the shop was and it turned out to be Valvoline muli-purpose red #2. I picked up some Valvoline full synthetic #2 (SynPower) and am greased everything on the truck. The truck DEFINITELY needed a greasing as it took quite a few pumps to get everything lubed properly (boots were very very empty). From what I've read on multiple other BITOG posts, the Valvoline full synthetic is hard to beat as an amazing "one gun for everything" grease. It isn't awful at ~$9/tube, especially since I won't go through it extremely fast only greasing my one truck (13 grease points - 11 ball and socket joints, 2 universal joints).
Current Rides:
Re: Best Chassis Grease [Re: Bdsankey] #5203635 09/03/19 01:10 PM
T
tundraotto Offline
T
Here is the delo spec sheet....I guess is not the low temperature that is the reason for the LB rating....delo is rated for lower temps than the mystik that is GC-LB
https://cglapps.chevron.com/sdspds/PDSDetailPage.aspx?docDataId=491507&docFormat=PDF
Re: Best Chassis Grease [Re: Rob_Roy] #5203676 09/03/19 01:47 PM
N
nthach Offline
N
https://www.nlgi.org/certifications/product/
However, Delo ESI #2 is Mercedes approved for their wheel bearings, which is odd. I used it for a repack on a friend's truck.
I've been using this lately for ball joint and tie rod lubrication, it's not GC-LB rated but I doubt WD-40 would risk their name with grease. It's a calcium complex grease, which is naturally water resistant and has inherent EP qualities as well. https://www.wd40.com/products/true-multi-purpose-grease/
Page 2 of 2 1 2
