Originally Posted by Navi
If 12 is the topline for 30 weight then at 12.9 0w40 is just a little higher. So when it gets diluted it s diluted back down into 30 territory for which the engine is designed. Probably will get under 12 within a 1000 miles or less.
So your vehicle will beat that oil to a 30 grade within a thousand miles or less? Wow, not good. I'd shorten the OCI to 4,000 or 5,000 miles max.
