Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
QS Conv vs. QS HM vs. PYB
by Fordiesel69 - 02/17/20 01:09 PM
Kia Proceed?
by WhyMe - 02/17/20 12:44 PM
RIP Donald Stratton
by 02SE - 02/17/20 12:41 PM
WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Predator35001819, Markapuu, jds59, JimMorrison, bjfangjd
70727 Registered Users
123 registered members (2002 Maxima SE, 2009Caraman, 2013ecof150, 53' Stude, AandPDan, 762fermeandyou, 10 invisible), 2,225 guests, and 21 spiders.
Topics301,580
Posts5,198,459
Members70,727
Page 2 of 2 1 2
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: DweezilAZ] #5201718 08/31/19 08:04 PM
E
earlyre Offline
E
Originally Posted by DweezilAZ
Gasoline additive. Or for adding to oil before a change.
I even have an oiler unit for it on my Valiant
how hard would it be to DIY one of those..( i know they're only like $60, but...I like making things)
would it work for tcw3? in place of dosing 1 oz /5gal fuel?
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: Imp4] #5201839 09/01/19 05:34 AM
L
Linctex Offline
L
Originally Posted by Imp4
Originally Posted by ZZman
Lubes fuel pump, upper cylinders and fuel injectors.
What is upper cylinder lube?!?
And how does it survive upper cylinder combustion temperatures???
On "port fuel injected" engines, the little bit of MMO enters the cylinder with the fuel mist on the intake stroke.
Most of the fuel vaporizes, but the oil mist lands on the cylinder walls, where it helps to lubricate the piston rings.
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: whatplsty] #5201855 09/01/19 06:34 AM
SandCastle Offline
...to separate a fool from his money.
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: whatplsty] #5201860 09/01/19 06:39 AM
L
Linctex Offline
L
I remember in the "old" days (1980's-1990s), it was the *SCHNIZZLE* for keeping pistons and piston ring grooves clean in aircraft engines (when added to the fuel).
These engines run on AvGas, which has high lead content.
MMO had/has:
tricresyl phosphate (an antiwear and extreme pressure additive, 0.1-1.0%), and
ortho dichlorobenzene (a softening and removing agent for carbon-based contamination on metal surfaces, 0.1-1.0%)
and it really worked great for helping keep aircraft piston engines clean internally.
My BIG questions is whether the formula has changed (gotten weaker) over the years or not......
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: whatplsty] #5202091 09/01/19 12:53 PM
Donald Offline
Originally Posted by whatplsty
I have a gallon of it (or whatever the big jug is) that I got for dirt cheap from somewhere I cant even remember. Anyway, whats it for? Is it used like seafoam?
Its always a Mystery why the stuff is still sold.
2015 Ford F-250 w/Powerstroke
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: Donald] #5202131 09/01/19 02:06 PM
dave1251 Offline
Indeed.
don't use.
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: whatplsty] #5202303 09/01/19 06:17 PM
M
Mad_Hatter Offline
M
Aside from what the label says, it's a high viscosity lubricant with mild solvent properties. And it's dirt cheap in the 1gl jug. (how much is a couple oz of 3 in 1?)... If you can't think of any uses for something like this, than you probably don't need it and should give it away to someone who can.
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: PimTac] #5202774 09/02/19 10:59 AM
W
Whimsey Offline
W
That would come in handy in case a big truck starts chasing you.
Especially if you're Dennis Weaver about 45 years ago grin2.
Whimsey
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: whatplsty] #5202779 09/02/19 11:02 AM
RDY4WAR Offline
Marvel Mystery Oil exists to make Marvel rich. That's it.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: earlyre] #5208376 09/09/19 09:21 AM
DweezilAZ Offline
It looks like a pretty simple device: a jar, a hose clamps and a brass tap.
I like the convenience of it as well. For me I am not much more than a remove and replace type, I admire people who can build such things on their own.
Here is the website: http://www.ampcolubes.com/
There are some great shots in the gallery and detailed pictures of the devices.
Seems they've added something about direct injection, etc and a good explanation of what it does with the MMO.
Re: Not sure where to post this but...what is Marvel Mystery Oil for? [Re: Linctex] #5208554 09/09/19 01:52 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by Linctex
...My BIG questions is whether the formula has changed (gotten weaker) over the years or not......
We don't really know but here is a thorough analysis from a few years ago:
MMO Lab analysis
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
Page 2 of 2 1 2
