Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
109 registered members (aba4430, 28oz, 90crvtec, 928, 1978elcamino, 2015_PSD, 7 invisible), 2,220 guests, and 23 spiders.
Topics300,387
Posts5,174,740
Members70,495
Page 1 of 3 1 2 3
2010 Accord VTC Issues #5200672 08/30/19 12:26 PM
P
Phishin Offline OP
P
History: Car had VTC Actuator replaced with Non-Improved part by Honda Dealer back in 2014/2015. Start up rattle showed up again in a few months. Start up rattle occurs about 20% of starts. Honda won't fix it again. I "bump" the starter, build up oil pressure in the VTC system, and this eliminates almost all the start-up rattle instances.
Last week my car was stumbling when I tried to start it. CEL came on, so did traction control. Threw P1009 code. Started fine a few minutes later.
Yesterday, the car gave the typical VTC Actuator grind when I started it (it usually only does it about 10-20% of the time) but this time, it was a longer than usual noise. Going down the highway, CEL and traction control lights on again. Come to stop light, and car is running rough at low speeds. I arrive at destination without too much trouble. Start car 1.5 hours later, and this time, the actuator noise begins AND DOESN'T STOP. Car is stumbling again. I immediately turn off because grinding sound is INSANE. I tried starting it several times, same thing keeps happening: VTC Rattle won't stop. 10 minutes later, I start it and it's running run. No high idle, no weird noises, no stumbling. I go straight home and haven't touched it since.
What do you think??
My local car mechanic says that he's going to check the oil pressure next week and if it turns out within spec, he'd consider fixing it. He also says the journal near the actuator can wear out and regular oil pressure and VTC oil pressure can mix and cause crazy problems as well (things he's seen in Non-Honda vehicles).
He suggest that I buy VTC Actuator, VTC solenoid, timing chain, and tensioners and he'll install but no guarantee it will fix my problem.
Any suggestions or insights??
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: 2010 Accord VTC Issues [Re: Phishin] #5200712 08/30/19 01:35 PM
F
FordBroncoVWJeta Offline
F
My 15 CRV had the VTC actuator problem too. The Honda dealership ended up replacing everything you mentioned.
EVERY time it started it would grind.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: 2010 Accord VTC Issues [Re: Phishin] #5200771 08/30/19 02:53 PM
A
ARCOgraphite Offline
A
I had this issue on a toyota year ago and people said I was full of it. smile
Maybe you can get a regular cam pulley or a welded/ or bolt locked VCT
Other than that IDK if honda have an actuator oil feed screen like they do on the VTEC oil feed.
- behind the solenoid.
Maybe thats gunked up (as would be typical after a few years)
I assume here its a wet system.
Some designs ( very few) employ a dry system.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 2010 Accord VTC Issues [Re: ARCOgraphite] #5200774 08/30/19 02:56 PM
M
mattd Offline
M
Did you ever do What was suggested in your last thread? If so what did you do?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: 2010 Accord VTC Issues [Re: Phishin] #5200815 08/30/19 04:00 PM
The Critic Offline
Assuming the oil is clean and full, check the VTC strainer to confirm that it is also clean. Test the VTC solenoid for functionality.
If those items check out, you need to remove the valve cover and verify mechanical timing.
My gut feeling is that you have a stretched timing chain.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: 2010 Accord VTC Issues [Re: Phishin] #5200923 08/30/19 06:12 PM
T
t1snwrbrdr12 Offline
T
I wouldn’t let him throw all those parts at it unless you just simply want them all replaced. It’s 15 min to check timing. That should be covered in his diagnosis fee, give him a valve cover gasket and tube seals so he can put it back together if timing isn’t off but it likely is. If the chain stretched you’d need a seal or two for the front cover, chain, tensioner, guides.
Re: 2010 Accord VTC Issues [Re: t1snwrbrdr12] #5201002 08/30/19 07:58 PM
P
Phishin Offline OP
P
I'm pretty convinced it's a stretched chain and it's out of time. VTC actuator needs replaced anyhow, because it's been rattling for a few years. VTC solenoid is just another $80, but as well replace that since he's right there.
But you are right, I'lln have him check oil pressure and timing before we order parts
Re: 2010 Accord VTC Issues [Re: Phishin] #5201043 08/30/19 09:08 PM
B
benjy Offline
B
if possible its time to dump that ride!! lots of deals these days + Kia-Hyundai are a good buy with loooong warranties!!
Re: 2010 Accord VTC Issues [Re: Phishin] #5201065 08/30/19 09:41 PM
1
14Accent Offline
1
It's not necessarily time to dump it. Is it an oil burner? Some K24's drink like cheap wino's, some barely touch it like it's poison. If you aren't having any oil issues, I say throw timing components at it. It's not a huge job, and all components have been updated. At least you caught it before a valve got damage.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 2010 Accord VTC Issues [Re: 14Accent] #5201975 09/01/19 09:44 AM
P
Phishin Offline OP
P
It consumes 0.5--0.75 quart in 7-9k mile OCI. Really nothing. I'll think to fix the car. It's been maintained to a high level. I'm not willing to throw in the towel yet.
Re: 2010 Accord VTC Issues [Re: Phishin] #5203474 09/03/19 07:51 AM
T
Tundragod Offline
T
That is NOT oil burning engine.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: 2010 Accord VTC Issues [Re: Phishin] #5205137 09/05/19 07:37 AM
P
Phishin Offline OP
P
Here's what I ordered yesterday:
Part Number Part Name
14210-PNA-000 Sprocket, Cam Chain Driven (46T)
14310-R5A-305 Actuator, Vtc (46T)
14510-R40-A01 Tensioner, Cam Chain
90032-PNA-000 Bolt, Flange (12X47)
90042-PNA-003 Bolt, Flange (10X32)
14401-R40-A01 Chain (176L) (Daido)
14520-RAH-H01 Arm, Cam Chain Tensioner
14530-RZA-A01 Guide, Cam Chain
14540-RAA-A02 Guide B, Cam Chain
15811-R40-A01 Valve Sub-Assembly, Spool
15811-R41-L01 Valve Sub-Assembly, Spool
15830-R5A-A01 Valve Assembly, Vtc Oil Control
Almost $900 in parts. All OEM Honda. This should fix any start up rattle and now P1009 codes and get my engine running back in time.
Re: 2010 Accord VTC Issues [Re: Phishin] #5205538 09/05/19 03:49 PM
T
T
You’ll need at least one o-ring / seal behind the timing cover and a valve cover gasket and spark plug tube seal kit. I didn’t replace the cam gears when I did my personal k24 timing chain job. I can understand why, but one of them is ridiculously expensive which I’m sure you found out.
Re: 2010 Accord VTC Issues [Re: t1snwrbrdr12] #5205737 09/05/19 07:58 PM
P
Phishin Offline OP
P
What year was your car?? The expensive cam gear is the VTC Actuator that "rattles" on cold starts. It's notorious on these engines. I think the Actuator was approximately $150, and the exhaust sprocket was like $80.
Thanks for reminding me about the gaskets.... I'll order tomorrow.
Re: 2010 Accord VTC Issues [Re: Phishin] #5205767 09/05/19 08:52 PM
clinebarger Offline
Why are you replacing the VTEC spool valve assembly?.....BTW, You have 2 listed......You only need one of them, Look at the back of the engine on the passenger side & identify which one you have. That is IF you decide to replace it? VCT Phaser rattle & P1009 isn't a good reason in my opinion!
15811-R40-A01 is the single Pressure Switch, Spool, Solenoid.
15811-R41-L01 is the dual Pressure switches, Spools, & Solenoids
[Linked Image from i.imgur.com]
2001 Chevy Camaro L92/4L80E
Page 1 of 3 1 2 3
