L locomaster1969 Joined Dec 14, 2015 Messages 206 Location Kansas Aug 30, 2019 #21 Mobil 1 5w30. Good quality oil filter. Change oil and filed at 10,000 mile intervals. I have a similar drive to yours. My 2000 Honda v6 accord is at 253000 miles and going.
A aquariuscsm Joined Dec 30, 2006 Messages 29,558 Aug 30, 2019 #22 Originally Posted by MetalSlug What is mm ? Originally Posted by slacktide_bitog Your Accord has the MM, which gives you the best OCI based on your driving conditions Any 0w20, 5w20, 0w30, or 5w30 will be fine for the full OCI suggested by the minder. M1 AFE 0w30 might be best for your usage. The OEM Honda A02 from the dealer is a Fram PH7317. If you want something a little better, step up to the TG7317. Probably the maintenance minder. My Accord has a wrench icon and a number that pops up on the dash when the oil life gets to 10%.
S slacktide_bitog Joined Mar 20, 2008 Messages 16,120 Location USA Aug 30, 2019 #23 Originally Posted by MetalSlug What is mm ? Originally Posted by slacktide_bitog Your Accord has the MM, which gives you the best OCI based on your driving conditions Any 0w20, 5w20, 0w30, or 5w30 will be fine for the full OCI suggested by the minder. M1 AFE 0w30 might be best for your usage. The OEM Honda A02 from the dealer is a Fram PH7317. If you want something a little better, step up to the TG7317. MM = Maintenance Minder Minder
